Pangolin alternator bracket install - Defender Source
Old August 9th, 2012, 05:24 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
With some minor tweaking of the metal it is in, and I can say this thing is more beefy than the rest of the truck! Metal thickness is really overkill but that is okay. Well worth the dollars. It does not come with instructions but it was no problem to figure it out by just holding it up in the correct spot based on the photos.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
ac, alternator, bracket, rack
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Bench seat install in '97 hartop timcd90 Defender Technical Discussions 1 February 15th, 2005 01:57 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
