paint suggestions for 73 series - Defender Source
Old January 11th, 2007, 10:13 AM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
this truck only has 60k original and is in excellent condition. it has been stripped and primed. any words of wisdom on paint. thanks guys. would like to spary it friday or saturday.
Old January 11th, 2007, 10:22 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I would have kept whatever faded patina was left on it. I have always thought that the light olive green(don't know the "real" name) with limestone wheels looked so classic. Sandglow is a great color too.
Old January 11th, 2007, 10:38 AM
Make sure you used etch primer . . . .
Other than that, NO BONDO.
Old January 11th, 2007, 11:11 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Q. What is the Dupont paint code used to find the original color of my Series Land Rover?
A. 38505A Limestone, 38503A - Marine Blue, 38506A Poppy Red, 38500A Bronze Green, 38504A Pastel Green, 42889A Artic White, 8177A Sandy Beige.
Just FYI in case you need it
Eric
Old January 11th, 2007, 11:13 AM
Do you have the code for masai red a la an 1984 110?
Old January 11th, 2007, 11:25 AM
mountainviewrover
MARK LECLAIR
Thanks Guys.
Ron,no Bondo What So Ever!
There Are Some Dents On The Rear Part Of The Front Left Fender But I Lfet It As Is. And Yes, I Used Etch Primer.
Kevin, It Had So Much Patina The Entire Hood And One Whole Door And The Wing Tops Were All The Way Down To The Aluminum.
The Truck Is In Such Good Condition I Had To Give It A New Paint Job.
So, The Original Color, Marine Blue It Is. Thanks For The Code, Les From Rovers North Gave Me The Same Code Number So I Know We Are Getting The Correct Color.
I Will Post A Picture Of It Once Completely Finished. I Have A Safety Devices Full Cage From A D90 I Had Going On It As Well And D-90 Rear Tire Carrier.
Thanks Again.
Old January 11th, 2007, 11:28 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Bronze Green, no doubt about that...
- Charles Eames
Old January 11th, 2007, 11:37 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Ron
I don't have anything on the 110's for paint codes.
Sorry
Eric
Old January 15th, 2007, 02:54 PM
mountainviewrover
MARK LECLAIR
pics with new paint
new paint job. what do you guys think it's valued at. 60k orig. overdrive, no rust! super clean. the engine was all redone. thanks.
ID:	7897   Click image for larger version
ID:	7899   Click image for larger version
Old January 18th, 2007, 08:06 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mark, what size tires are those? can you send me a good side pic? Im trying to figure out a set of tires for my series.. How did the d-90 tire carrier fit on the series? Pics?
Legend in My Own Mind.
Old January 20th, 2007, 02:27 PM
mountainviewrover
MARK LECLAIR
goodyear mtr's size 245-75-16's.
the tire carrier went on great. i did the same when i built my 69. i bought a used d90 carrier and fit it to the series just as you would to the d90. 4 holes will need to be drilled for the top hinge, the ones through the body. use big washers or a plate to reinforce it.' then the bottom hinge uses the existing body mounts and you need to drill another hole through the rear cross member. the other hardware is mounted to the swing gate as in the picture.
pictures
ID:	7943   Click image for larger version
ID:	7945   Click image for larger version
Old January 20th, 2007, 04:24 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
That marine blue is beautiful. Someday I want to repaint my truck to a blue, probably Arles.
Are you gonna repaint that tire carrier and mount it w/ stainless hardware?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
paint, series
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
Suggestions On Lift A Series Iii. mountainviewrover Series Technical Discussions 3 November 21st, 2006 09:36 PM
Paint Color/ Paint Code little black duck Defender Technical Discussions 3 March 16th, 2005 05:30 PM
Paint Code? Trigger Defender Technical Discussions 4 June 17th, 2004 01:45 PM
