overall height of 109 truck cab - Defender Source
Old July 31st, 2011, 04:56 PM
Dr Benway
Haydn
none
greetings
I've been trying to find the overall [clearance] height of a sIIa 109 truck cab.
Ive found some LR manuals on line and they give it as 11cm [over 4"] more than an 88 truck cab?
1.95m vs 2.06m
is that correct? if so, what makes the 11cm difference?
can someone measure their 109 truck cab please?
1.95m clears my garage door, 2.06m only clears my garage door at speed.
thanks!
Old August 1st, 2011, 01:26 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I cant answer with any authority but I believe the difference would be because of the different types of rear springs. I think Teriann has info on the different spring rates on her site somewhere (iirc). It would make sense that a truck with stiffer springs, with the weight of the hard top gone and replaced with a truck cab would sit higher.
Daniel
Old August 1st, 2011, 01:34 AM
Stock 88" came with ~28in tires and 109s came with ~32in tires. There is 2in. Rest is in the springs.
Old August 1st, 2011, 07:49 AM
Dr Benway
Haydn
none
thanks all, for the replies
attached here is the specs page from the sIIa owners manual
thanks!
Old August 1st, 2011, 12:50 PM
The Dro
Dro
1988 Ninety
Haydn,
The data you will find is almost useless...
I say this because, the overall height will be dictated by the tires and saggy/upgraded suspension components used.
My IIA had 225/75-15 (about 28-1/4" tall) on it and it went up about 3-1/2" when I got the 235/85-16 (about 31-3/4" tall).
Hope this helps.
Old August 1st, 2011, 01:09 PM
Originally Posted by rrc.swb View Post
Haydn,
Hope this helps.
That is mathamatically impossible. You only gain half the tire height difference in lift as only half the tire is under the axle.
Old August 1st, 2011, 04:33 PM
Rugbier's Avatar
Rugbier
Gustavo
Pedro ...Pedro..... repeat after me PI = 3.1416 *LMAO*
Radius = D / 2 or C/2 n or square root of A / n
Damn engineers
where:
D is the diameter of the circle
where:
C is the circumference of the circle
π is Pi, approximately 3.1416
where:
A is the area of the circle
NO SIGNATURE
Old August 1st, 2011, 06:49 PM
The Dro
Dro
1988 Ninety
You guys are correct... I chose the wrong wording. Meant to say the tires have a 3-1/2" difference in height.
But my point still the same... Over all height is very difficult to guess from books.
109, ht
NTO Defender Truck Cab Firewalls FS SafariHP The Vendors Loft 1 July 13th, 2011 08:44 PM
Wanted: Pick-up cab for Series III 109 DG Rodgers Wanted 1 April 12th, 2009 10:01 PM
110 Truck Cab Firewall for HI Cap SafariHP The Vendors Loft 2 February 23rd, 2009 09:01 AM
Looking for a Truck Cab abraded Wanted 6 December 19th, 2007 05:50 PM
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
