Ok tell me I'm not mental - Defender Source
Old October 8th, 2011, 08:52 PM
Is it not true that a third from a D1/RRC will bolt into a series axle housing and be perfectly ok? Pedro and I were discussing this and I think it's a go. Am I wrong?
Old October 8th, 2011, 10:29 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I've never actually done it but I believe the complete third does actually bolt right up. There is the obvious spline count difference between disco 24 spline and series 10 spline.
Daniel
Old October 10th, 2011, 10:21 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Unless you are planning on putting in something bigger than a 2.25 I would not suggest the swap. It makes a stock series rover a real dog and that is saying something.
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old October 10th, 2011, 11:47 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Not this time. My LR's front end currently has a Range Rover Classic housing installed.
If you use the wider 3.45:1 R&P or 4.75 R&P or 4.7:1 R&P with a RRC carrier, a locker or limited slip that requires a spacer plate you will need to grind the opening for the ring gear a little wider but that is it.
My front end is currently, SeriesTrek 24 spline axles, Trutac diff, 4.75:1 R&P on a RRC pumpkin in an early SII (not A) housing.
In the attached picture, the diff on the left is a RRC pumpkin, Trutrac 24 spline limited slip and 4.75:1 R&P.
Diff on right is a Series pumpkin, Quaife 10 spline limited slip, 4.7:1 R&P with spacer plate. Both fit in my SII axle housing after metal was ground off allowing the wider 4.75 ring gear or 4.7 Ring gear + spacer to pass through.
TeriAnn
G4 jimmy salmon Misc. Chit-Chat 8 March 11th, 2005 08:46 AM
