Oil Pressure - Defender Source
Old October 1st, 2015, 10:28 PM
seanman
Sean McLaughlin
Just purchased a 72 Series III....
Oil Pressure
Hello...
Recently purchased 72 Series 3. When i received it, the oil pressure light worked normally....on when ignition key turned, off a second or so after engine starts. Never flickered at low idle. It also has the oil pressure gauge, looks to read around 30-40lbs at cruising speed.
Just today, the oil pressure light came on, and stayed on at cruising speed, but the gauge still reads 30-40lbs as it did before. I checked, didn't see any loose wires. Engine temperature stays normal....
Think its a faulty sending unit? Any way to test?
Attached is picture of gauge reading.
thanks in advance.
-Sean
Old October 5th, 2015, 08:24 PM
seanman
Sean McLaughlin
Turned out it was a bad Sending Unit. Fell apart in my hands when I took it out.
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Oil pressure gage rover4x4 Defender Technical Discussions 4 November 30th, 2004 09:44 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
