Oil level gauge for a Fairey Overdrive - Defender Source
Old June 28th, 2013, 09:21 PM
cdb
Clark Bowen
Before I install the overdrive, I'd like to tap it with a sender that flashed a light on my dash if it needs oil.
Has anyone done this?
2011 RR HSE -
2001 GMC 2500 4wd
Old June 30th, 2013, 08:20 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Be sure to wire it so the light is on in the "on" position. Would suck to be relying on a light that is burned out. Or, at the least, use a light that has a test function, like the SIII brake warning light setup. Then you can at least manually test it, provided you remember to.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 30th, 2013, 04:10 PM
cdb
Clark Bowen
Thanks - that seems like a good way to go.
Now, if I could just figure out how to do it - i.e. what type of sensor?
2011 RR HSE -
2001 GMC 2500 4wd
Old July 3rd, 2013, 10:18 AM
Howsomever
Wayne Phelps
1984 D110
Another thought
Depending on how you do this you may have issues cdb. What you propose could only be active when not running the gearbox. In motion the oil is no longer pooled at the bottom but in motion everywhere from gear and shaft action. What I had thought about was a plastic sight tube......vertical and using banjo fittings tie to drain and fill plug holes. Then when stopped I would have a visual indication on sight tube. In the end it is best to check it often.
Old July 7th, 2013, 08:55 PM
cdb
Clark Bowen
Thanks Wayne....
Yes, I figured that it would be like the Porsche 911 which reads the oil level before you start it.
I like your sight tube idea, but how would you be able to see it without pulling the center seat and metal plate?
2011 RR HSE -
2001 GMC 2500 4wd
110 Oil Light and temp gauge bjf Defender Technical Discussions 25 May 26th, 2009 09:45 PM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
