Nuts and Bolts Kit - Defender Source
Old June 30th, 2011, 11:50 AM
The Dro
Dro
1988 Ninety
Nuts and Bolts Kit
I'm missing several nuts and bolts that hold the wings.
Is there a body/panel kit already pre-made for the Series?
Old June 30th, 2011, 12:41 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
check out tntlr.com, and there is a UK company that sells fastner kits for rovers.
Old June 30th, 2011, 01:30 PM
The Dro
Dro
1988 Ninety
Thanks!
Tntlr is going out of bussiness... he's retiring.
Old June 30th, 2011, 03:14 PM
airbornrover
William Skidmore
SIII 109 SW
Wha? I wasnt aware of that. Thought he had his kid working with him?
Old June 30th, 2011, 07:18 PM
texrover's Avatar
texrover
Jason
Try George at Rovers Down South he usually has most small bits and more.
Old July 4th, 2011, 08:39 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
7/16ths fine thread is your friend. The will hold on most body parts on your Rover that uses bolts for fixings.
The special bolts to mount your wings to the bulkhead are available new at any LR parts house as are the special bolts and speed nuts that hold down your floor panels.
There is a metal strip with threaded studs used to hold the front left wing to the radiator bulkhead that may be NLA. George at Rovers Down South may have some. If not Ike at Pangolin will likely have a used one for you.
That's pretty much all you need for wing fixings.
TeriAnn
Old July 4th, 2011, 10:25 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Nope. Closing his doors. Everything is on sale,
Semper Fi!
Old July 5th, 2011, 12:23 PM
The Dro
Dro
1988 Ninety
Those are the ones I need.
Thanks for the info.
P
Old July 5th, 2011, 01:14 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
RDS usually has it all. Otherwise check Rovahfarm.
bolts, kit
ROAV Summer Nuts and Bolts Rally July 31-August 2 ukoffroad Trips, Trails and Events 16 August 4th, 2009 12:44 PM
What thread pitch are the big bolts on the tire carrier and the lug nuts? evilfij Defender Technical Discussions 5 April 20th, 2009 02:38 PM
Nuts and bolts ... Retrofit Defender Technical Discussions 8 August 11th, 2007 05:39 AM
Door Sill (Carpet) Trim - D90 Wagon Kimos Defender Technical Discussions 14 October 28th, 2004 08:55 PM
Stripped nuts on the driveshaft... dmarchand Defender Technical Discussions 13 November 18th, 2003 09:41 PM
