Not enough boost. - Defender Source
Old August 25th, 2014, 08:20 AM
Not enough boost.
K, it looks like I'm only getting maybe 3 psi of boost. I suspect that I have a loose clamp somewhere that's letting all the pressure out. I double checked the waste gate and it has about 1/2 inch more or less of travel from slack to where it has to go on the pin.
Old August 25th, 2014, 08:24 AM
NPT90's Avatar
NPT90
JT
D90 ˇriginalÚ
There are better ways but I've found that a compressor hooked up to the boost gauge hole can quickly help you locate the air leak (most of mine have been at the bottom of the intercooler because it shifts during install)
Old August 25th, 2014, 08:48 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
3lbs is pretty short on boost.
Split hose? (do you have the Terrafirma silicone hoses yet?)
I bet that if it were a confined area which was leaking (like through a loose or broken clamp) , you'd hear it whistling, but maybe the signal tube to the injector pump melted or cracked too so check those lines.
Hope its not a bum turbo.
EDIT: is it down on power (obviously its down from what it is normally because its lacking boost, but I mean pre-boost, off-the-line power)?
Could it be fuel starved, running lean for some reason? maybe injector pump issue? I'm just thinking that if you can't find a leak that maybe there is not enough combustion occurring to create the exhaust flow. That's my Jr. Associate stab at it, so I'll defer to Overlander or Uncle for better clarity.
Old August 25th, 2014, 09:33 AM
Everything is brand spanking new. Ally tube and silicone elbows with t bolt clamps.
Old August 25th, 2014, 09:42 AM
the rover shop
shayne young
Connect a pressure gauge to the waste gate valve and blow compressed air into the signal hose very slowly and see when the waste gate rod starts moving... If it moves at 3 psi then adjust it until you get the desired boost pressure...if it doesn't move until 8-10 then yes.. You have a leak somewhere..or the turbos not generating boost.. With the end of the hose where it goes onto the intake manifold you can remove that and hold your hand over it and give the engine a bit of a rev.. You will very quickly hear where the leak is if there is one..
Old August 25th, 2014, 09:53 AM
Shop vac blower side into the turbo inlet to look for leaks.
I assume you are driving it as you need load to get boost. What are smoke levels like. There needs to be excess fuel to get boost. If there is no smoke, something is not setup correct to get fuel in there.
Old August 25th, 2014, 09:59 AM
Jackie Treehorn
A
1985 (legitimately)
This is sorta what I was thinking. Test for leaks, then move on to fueling, but since you're telling us things are brand new, maybe its one of the connections like Jason mentioned. Yes, that lower one can be a PITA. You'd think there's be more margin when hooking rubber hoses up, but with the ridged pipe on the bottom (feed to intercooler) and the small flange area, it can be tricky to line those up.
Shop vac is a good idea, I've used this as well. the shop vac hose is pretty damn close to the size of the plumbing.
Old August 25th, 2014, 10:26 AM
Bill are you sure wastegate is seated/closed. Pulling the pressurized vacuum tube going to the wastegate will prevent it from opening and should allow you to test if that is the issue. Can you hear turbo whine, ie is it free and spinning ? From memory you have some pretty intricate boost side plumbing going on. Hopefully its just a leak, you can usually easily hear them when they are that major.
Old August 25th, 2014, 10:53 AM
Yes Doug the wastegate is closing and moves freely. It could be that the boost gauge is not reading properly, that is to say, I don't have it set up correctly (Auber instruments boost gauge). I don't hear any leaks in the piping. I will test the wastegate actuator with compressed air. I will recheck that the turbo spins freely when I investigate all this again this weekend.
I would ultimately like to have you or someone take a look at it at Conclave.
Old August 25th, 2014, 11:51 AM
NPT90's Avatar
NPT90
JT
D90 ˇriginalÚ
Thats genius, I usually make a whole adapter at the hardware store for the air compressor... I've wasted hours of my life I can't get back...
Old August 25th, 2014, 12:38 PM
Bill if it has any acceleration @ all and runs nicely @ highway speed I would suspect the gauge.
A 200 with no boost is a dog with less hp than a 2.5 natural.
If you rev the engine and can see the flex sections of intake pipe expanding you have boost.
boost
My garage doors are not high enough ADK46er Defender Technical Discussions 19 September 26th, 2011 03:58 AM
Not enough demand for NAS Defenders rover26c Misc. Chit-Chat 11 October 23rd, 2009 09:30 PM
door tops over tightened or not enough? atlawson Defender Technical Discussions 6 January 31st, 2008 09:00 PM
when the 90 is not tough enough 1000kva Misc. Chit-Chat 2 October 1st, 2007 12:27 AM
finally, fixed enough for photos januconn92 Misc. Chit-Chat 3 July 23rd, 2004 09:01 AM
