No start in cold - Defender Source
Old January 22nd, 2013, 07:23 PM
No start in cold
It finally got cold here - in the high teens this AM, and my poor 63 2A is banished to being parked outside while I waste precious garage space with my crazy EV project. Anyway the starter wouldn't even click - not sound at all. I of course pulled out the hand crank and went on my way. When I got to work, I could shut if off and fire it right back up with the starter as normal.
Same story when coming home.
I assume I have a not-tight-enough connection somewhere that is getting loose when sufficiently cold. Any other theories?
TIA
charles
Originally Posted by pendy
I'm here for the D's
Old January 22nd, 2013, 07:40 PM
bad brushes or stuff in there that is freezing the internals, then when the engine is hot it breaks it all up??
Old January 22nd, 2013, 07:53 PM
It's a relatively new gear reduction starter and works like a champ otherwise. I did wash the undercarriage on Sunday but drove it later in the day and it should have all dried out by now, especially after being driven again yesterday and today.
start
D90 cold start problems aquamanaquaman Defender Technical Discussions 3 November 25th, 2012 05:03 PM
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Cold start problem flippedrover Defender Technical Discussions 3 February 13th, 2008 06:52 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
