No electrical power??? - Defender Source
Old April 19th, 2012, 08:23 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
I have a 94 NAS d90 and have had it on a battery tender for the winter and started it occasionally but today I went out to actually drive and there was no power?? I mean nothing no lights no radio. No flashers and nothing when the key is turned? Is there a main fuse? Or something any help is much appreciated Thanks in advance Rob
Old April 19th, 2012, 10:26 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Maybe your truck has a smnall small short, that has gotten worse to the point where the batt got drained. Or a crappy connection to one of the batteries posts or main cable connections. Or your battery just died.
Does the ignition switch feel fine? Mine once spilled its guts out the back if I recall, and I had nothing. (Besides a new problem!!)
let us know what you find..
~Steve
Old April 24th, 2012, 07:59 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
Thanks for all the great advise but I'm a goof the battery was super dead i assumed that since it was on a trickle charge it would be fine not thinking the charger may have gone bad..... yeah I know what assume means thanks again ROB I do have a small short that drains the battery in about a week so I'm going to put a main on/off switch in that seams like the easiest fix as I can't find where it's draing from?
Old May 13th, 2012, 05:44 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
My 109 has some kind of small short - battery is charged enough to start for a few days, but if it sits for a week, it needs a jump.
I'm an electrical troglodyte, so one thing that has helped are those high tension battery disconnects that use the big red plastic / metal contact keys. They're great and very reliable, so my 109 will be getting one soon.
I got mine from Matthew Savage - great guy to deal with.
Good luck.
electrical
Electrical Power Drain JimKo Defender Technical Discussions 22 March 26th, 2013 03:59 PM
Electrical Issues bossman429 Defender Technical Discussions 3 October 6th, 2011 10:25 AM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
