New Brake Issue - Defender Source
Old June 19th, 2010, 11:45 AM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
New Brake Issue
Ok so I completely replaced everything brake wise except the backing plates. When I put the drums on and tighten them down I can barely turn them. When I install the wheels and torque down the lugs I can't turn the wheels at all. I have taken them off checked everything a billion times. The shoes are completely backed off and in fact when I slide the drums on they touch nothing. I checked the tolerances between the face of the shoes and the inside of the drum and I have a good 20mm. I even put washers on the studs between the hub and the drum and still have the same problem. I also checked the distance between the backing plate and the drum and I can slide a paper in. I am completely baffled.
Old June 19th, 2010, 12:11 PM
I'm assuming this is the standard 10" brake setup for the 88"? Are you using the correct diameter drums? 20mm sounds like a lot of clearance. Are you using the screws to hold the drums in place? I've been leaning toward leaving those out myself but they shouldn't cause this problem.
Old June 19th, 2010, 12:31 PM
I have seen "oversized" shoes sold which are designed for drums that have been turned (which will not fit on new drums). Where did you get the shoes and drums?
Old June 19th, 2010, 12:41 PM
bcourtney's Avatar
bcourtney
Robert Courtney
Sorry that would be 2mm. The parts are all off the shelf at AB. I just looked at them again and I can see I have contact with the shoes and drum right on the top on the braking surface. Granted I have not driven this yet or even put fluid in the system. This is all just from pushing it around the shop. I may need to wait and see when I finally get it on the road and do some driving.
Old June 19th, 2010, 05:02 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
I had similar issues, but with 11" brakes.
Check to make sure that the pins on the shoes that contact the adjusters are not too long. Mine were, and the pins hit the adjusters, causing the shoes to be out of square with the drums. The drums went on fine, but as soon as I tighened them down the drums would not turn. I trimmed the pins to match the original factory shoes and all was well.
Old June 19th, 2010, 06:58 PM
bcourtney's Avatar
bcourtney
Robert Courtney
Thanks Jeff I think I noticed they were longer I'll give that a shot
brake
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
Soft Brake Pedal Issue.... greend90SW Defender Technical Discussions 3 December 29th, 2007 02:25 AM
3rd Brake Light Issue fleabus Defender Technical Discussions 2 February 7th, 2007 07:49 PM
