My fupped duck Bulkhead - Defender Source
Old December 5th, 2011, 12:29 PM
Got it back from the stripper and find that most of what has been holding things together has been rust. Fortunately it all got cleared out and what's left of the miserable thing is more or less the dash. Looks like the footwells on both sides as well as the door posts and the area next to the vent openings is all rot.
I have previously used the Rovers North panels to repair the LH footwell, and that has actually stood up well to corrosion as it was galvy.
I like them because they seem to be the only ones that have the stiffening ridges molded in. I guess I am asking whether there are any other panels out there that are of similar quality but less dear to the wallet?
OK ordered the foot wells and center section from RN. Need the door posts that go up high enough to do the curve.
Old December 5th, 2011, 01:28 PM
Check with Pedro as I believe he has these.
Originally Posted by pendy
I'm here for the D's
Old December 5th, 2011, 01:44 PM
OK Found the rest at M M 4WD in the UK.
Old December 5th, 2011, 01:46 PM
The Dro
Dro
1988 Ninety
Bill,
Do you need the ones I have?
Old December 5th, 2011, 02:35 PM
Yours don't go past the bend if I recall. I found some that do. Thanks anyway.
Old December 5th, 2011, 03:48 PM
this thread is worthless without pics
Old December 5th, 2011, 03:58 PM
Well, until I get some posted just imagine really clean steel that looks like a coral reef, without the fish.
Old December 5th, 2011, 04:20 PM
like this?
Old December 5th, 2011, 04:29 PM
Pretty much. I'm actually looking forward to the zen of renewing the bulkhead. I had planned to send it out to be done, but the budget will not sustain such notions. I need a cut off wheel and some vise grips and some magnets and stuff. Guess I will also make an alignment jig out of angle to hold the bulkhead shape while working it over.
Some of the repair panels are on back order from RN, and the stuff coming from the UK, well who knows. Maybe by the end of the year it'll be ready for surgery.
Old December 5th, 2011, 04:45 PM
Bill have you checked out yrm metal specialties ?
Old December 5th, 2011, 06:48 PM
Yes, Doug, thanks. They have a lot of good stuff, but nothing I need at present.
Old December 5th, 2011, 08:06 PM
JBinAlabama
john
Series 2A ..more parts on the way
I wondered if you would find what I did on the stripper!
My sandblasting left nice clean steel and a few spots I didnt find with the screwdriver test (jab)
When the acid dipped it then galvanized a few new holes appeared
It sucks after all that work for certain.
Did you find the taller door post at MM then?
Old December 5th, 2011, 11:44 PM
Yes m m has them that go all the way up to the second hinge. 46 I think per side.
My bulkhead will be like new when I'm done.
I'm going to have it galvanized and then it gets shot with Interlux Perfection. I understand it has to be coated within 48 hours or else you have to wait a year, so I gotta have my timing just right.
Old December 6th, 2011, 06:46 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
So I can take you off the schedule then?
.......and the thing about waiting a yr if not done immediately is a myth as far as i am concerned. I paint galvy stuff all the time and it is never within 24 hrs and mostly not after a yr. I do usually leave it outside for a bit.
Matt Browne
Old December 6th, 2011, 07:40 AM
Yah, Thanks Matt. I'm sorry we won't be doing business this time.
Old December 6th, 2011, 07:48 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Hey, no worries at all Bill. Not like I'm sitting around twiddling my thumbs waiting for bulkheads to show up LOL. Just means someone else gets theirs back sooner.
Matt Browne
Old December 7th, 2011, 12:01 AM
Albersj51
jason
1967 2a
Junkyddog,
What do you use For prep and primer to paint galvy to get good adhesion? I had my bulkhead and rad panel dipped a couple of months ago and I want to start painting soon.
Old December 7th, 2011, 07:55 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Unlike some other shops I don't do my own paint (I have an excellent body shop that understands Land Rovers right in the same building so why bother).
They use DuPont 5718S which is a conversion coating for galvanized surfaces (or steel). Then it gets epoxy primed and painted with whatever the specific job requires. The conversion coating is the key I think. I have also used the "Primergalv" coating right from the galvanizer, but have not noticed long term that it is any better.
Matt Browne
Old December 7th, 2011, 06:22 PM
Albersj51
jason
1967 2a
Excellent. Thanks for the info.
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
