My freakin hand brake (RHD) - Defender Source
Old October 29th, 2010, 09:54 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
The pivot point at the chassis bracket. Can someone tell me why when I replaced the circlip and washer (genuine)it wont stay on when I pull up on the hand brake to engage the tranny brake. About to take the BFG to it. And yes the circlip is in the groove.
Old October 31st, 2010, 04:00 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Post a picture of the problem.
Mike Hammond
Old November 1st, 2010, 08:23 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
My bet is that the groove in the pivot shaft is worn/corroded, causing the circlip to pop out if it sees any axial load at all. Take a piece of safety wire and wire the clip together using the small holes in the ends. If this solves your problem, you most likely need a new shaft (if the groove is damaged) or the circlip was bent at installation.
Old November 1st, 2010, 09:06 PM
airbornrover
William Skidmore
SIII 109 SW
Thats what I was afraid of. The only reason Im having this problem is cause I was like "Oh look at that I am missing a washer with only the circlip holding everything in place, let me fix that" (Rover gods laughing)
Old April 8th, 2011, 01:19 AM
airbornrover
William Skidmore
SIII 109 SW
Tie up loose ends as it were. Of course it was something dumb simple to fix. The curve in the vertical rod which I thought was suppose to be orientated front to back is actually left to right because the brake linkage at the chassis is slightly offset from the handbrake lever itself. SSSSooooooooo damn simple of a fix.
brake, rhd
RHD to LHD conversion question Gkase Defender Technical Discussions 14 September 14th, 2008 08:01 AM
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
RHD D90/110 Steering Guard JohnC The Vendors Loft 0 November 4th, 2005 02:02 PM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
For Sale : 1985 D110 RHD Bill Jansz For Sale - Vehicles 0 March 11th, 2004 10:35 PM
