Mounting the bulkhead on frame issue. - Defender Source
Old June 21st, 2016, 11:45 AM
Maineguide
Dan emidy
1972 series 3 88
Hello,
I am still working on the 72 88 on a 2a frame. I am installing the bulkhead and I am having an issue with the holes for the mounting bracket off of the steering box. The holes are an inch low and about an inch toward the front. Are these 3 holes different on a series 3 frame? Bulkhead seems about square and in right.
Old July 2nd, 2016, 01:18 PM
Michel's Avatar
Michel
Michel Bertrand
1991 110SW 200tdi, 1963 109 2 door
Had no issue installing a IIA bulkhead on a Ser III frame, on two different 109s. I always thought that they are interchangeable. My left wing is off at the moment, I could take some measurements if that can help you.
Michel
Old September 12th, 2016, 05:58 AM
gratton4
David Gratton
1960 Series 2
Originally Posted by Maineguide View Post
Hello,
Hi there,
I just came across your post and recognized the issue that I had at one point.When assembling the bulkhead to frame and steering bracket, I was told not to bolt everything down tightly until you have the bulkhead, doors and steering all in place , so that you can adjust so that the door gaps and and bulkhead can be squared up. Once everything is in place and possibly shimmed ,then you can tighten it down. I made not of the bolts that needed to be tightened , so they don't get forgotten later.
Sent from my iPad using Tapatalk
Old September 12th, 2016, 12:08 PM
Half an inch of shims is not unusual there. As said, there are some things that can't be adjusted (bulkhead vertically because of the two big bolts at the bottom), but everything else has a lot of adjustability. Bolt it up very loose and add shims as needed including washers to move the bulkhead forward. Was your bulkhead repaired? That could also explain the gap if it is really a full inch off.
mount
Trying to drop motor on new frame issue. Maineguide Series Technical Discussions 7 June 19th, 2016 06:51 PM
Battery Issue or Charging Issue? icnsltmfg Defender Technical Discussions 4 May 19th, 2016 01:25 PM
bulkhead mounting bolts? boswalt Defender Technical Discussions 0 April 4th, 2013 06:23 PM
Galvanized Rear suspension a-frame to chassis mounting brackets dave_lucas For Sale - Parts 7 December 18th, 2010 04:52 PM
Snorkel mounting to window frame - pics? wicks Defender Technical Discussions 10 January 4th, 2009 07:06 PM
