Mid row seat installation help - Defender Source
Old May 19th, 2016, 09:25 PM
Noyac40's Avatar
Noyac40
1985 D110
Hi, I am replacing my rear vinyl bench seat in my D110 5 door with a 3 -piece cloth set that I purchased from a forum member. I received a box of hardware and seats that I have no idea how to install. Does anyone have these seats, and if so, can I ask for a bunch of pictures showing how these go together? Thanks in advance.
Old May 20th, 2016, 12:04 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I'm doing this right now. I haven't taken too many pics but figured some things out. I had to remove all the brackets for the bench seat first so I could test fit things. You will have to drill some holes. Also, my bench has the locking mechanism up high so I had to remove it from the bench seats and add it to the high backs. They are in now but I need to get some grade 8 bolts and backing plates before they will be ready.
Old May 20th, 2016, 08:55 AM
Noyac40's Avatar
Noyac40
1985 D110
That looks great, my seats aren't as nice but still better than the current ripped vinyl bench. Thanks for this pic, if you happen to get more pictures of the brackets that would be great.
Old May 20th, 2016, 09:02 AM
just a suggestion but you could download the factory workshop manual and use that
Old May 20th, 2016, 09:44 AM
Noyac40's Avatar
Noyac40
1985 D110
Good suggestion, thank you. I just took a look and figure 76-4 shows seats from top but doesn't get into the weeds on the brackets.
Old May 20th, 2016, 11:00 AM
Sometimes you have to combine the parts books pictures with the workshop manual as the workshop manual/ pictures leave a lot to be desired. If you want to text me I can send you a couple pictures that might help. The early ones used a spring loaded slide bolt/latch that sound like what you might have.
Old May 20th, 2016, 11:04 AM
Noyac40's Avatar
Noyac40
1985 D110
Will do, I appreciate the help.
installation
110 ROW 2nd Row seat Cajun For Sale - Parts 3 March 27th, 2015 05:51 PM
Defender muffler/exhaust mid-silencer mid-box Ben01 For Sale - Parts 2 February 23rd, 2015 01:04 PM
97D90 Alternator installation help 97Ariesblu Defender Technical Discussions 17 September 10th, 2011 06:25 PM
Hannibal rack installation help GaryBaxter Defender Technical Discussions 6 September 17th, 2007 06:05 AM
Need some help/advice with rear seat installation Paul Davis Defender Technical Discussions 4 July 20th, 2006 10:01 AM
» Defender Registry
Brown Truck
98 HOO
White
KGH
Add your Defender
