many questions in regards to my build - Page 2 - Defender Source
Old October 25th, 2012, 01:59 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Whoups...I understood you sold the axles/Series to someone who turned it into something...on portals.
Just being curious, there aren't many around to see.
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old October 25th, 2012, 02:13 PM
Viggen's Avatar
Viggen
Jarrod
none
Originally Posted by killahaas View Post
where would i find those axles?
I just sold my BJ60 Land Cruiser and have built up Cruiser axles. 40 series axles are easy to find because many 40 owners are upgrading to 60 axles for strength and extra couple of inches of width. Go to IH8MUD and look through their classifieds section. Youll find a set really easily. 60 series axles are just about equivalent to Dana 60s in strength.
Old October 25th, 2012, 02:36 PM
aka rover's Avatar
aka rover
ed angel
95 D90
thanks, i still think i am going to exact route you are going. i may contact you in regards to the GBR gears.
Look me up I would be glad to share anything I know with you.
85 D110 3.5 3 DR
Old October 25th, 2012, 07:57 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
so does anyone know if just disco 24 spline axles will fit in? or disco axles longer? or what?
Dylan.
Old October 25th, 2012, 09:11 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
my front diff has a fill plug in the case the rear diff does not. but either way. i think i am lean towards buying discovery I axles and modifying them to fit. there is a guy on the RN forums who has done it and i am waiting on better pictures and a few more details but so far it looks to be the better way of doing this when it comes to how much the axles and disc brake conversion will cost.
Dylan
Old October 25th, 2012, 09:30 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Dylan
You are all over the place lol, last you told me you wanted to just do the Timm copper discs haha.
Old October 25th, 2012, 09:40 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
it looks like it will be so much cheaper to do that.
Old October 26th, 2012, 12:16 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Coiler housing and inner shafts are longer. The Diff (complete 3rd member) will fit in your housing, but you might need to ad a fill plug if your housing doesnt have one.
-Jeff
Jeff is right you will need to add a fill plug and 4 of the studs need to be swapped out for longer ones, both an easy job. I just did a swap on a series .
85 D110 3.5 3 DR
Old October 27th, 2012, 04:50 AM
aka rover's Avatar
aka rover
ed angel
95 D90
I agree with jeff on this as well, I looked into doing this and its not a straight forward swap. The steering issues alone are a challenge, if you want to keep the castor in the ballpark.
85 D110 3.5 3 DR
Old October 27th, 2012, 08:03 AM
I know one series 88 on portals. Best used off road only.
Old October 27th, 2012, 11:08 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
So like I said earlier if it was a good idea it would have been done over and over many times by now.
The front axle is the real challenge. The pumpkin on the coiler is more to the right than a series. The axle tube starts to spread right where your spring perch needs to go. IMHO this could limit up travel significantly without some creative work on your spring perch. There isn't much up travel on a stock series as it is but there would be less with a coiler axle I think. Then there is the issue of the location of the track rod and drag link. Series has them both up front, coiler has drag link up front and track rod hanging low behind the axle. You'd have to modify these I think to fit around the springs but maybe you could clock it somehow to fit but then you'd be changing the caster angle. Others have gone this route and documented it online. There is a build somewhere on expedition portal and pirate iirc.
I wouldn't have used coiler axles if I wasn't doing the spring over and even doing that it was alot of work to get the steering to where is is now and I'm still not sure it will work (keeping my fingers crossed for no death wobble and that my welds on the swivel housings are good!).
Its always fun to try though so if you're motivated and have the parts in hand don't let us nay sayers slow you down! Just don't think it will be a straight forward job and start in the front because if you get it to work the rear will be easy.
Here is a pic to show what I was saying regarding the location of the pumpkin vs the spring. You can see that the axle tube spreads out. I had to grind the perch to fit and its still not totally level where the spring sits. Hope this helps.
Daniel
Old October 27th, 2012, 01:09 PM
JohnsD90's Avatar
JohnsD90
Daniel
You couldnt tack a small lip on the bottom to keep the u bolt from moving?
Old October 27th, 2012, 01:25 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
On my build? The those ubolts are snugged up to the spring perch and can't move. The longer one is also snugged up on the back side between the perch and the diff housing too. Thanks.
Daniel
New door build up questions jayz Defender Technical Discussions 3 September 23rd, 2012 10:41 PM
Build Questions saber6 Defender Technical Discussions 6 January 13th, 2011 12:55 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
