LT 95 gearbox..do I have to remove gearbox from truck to replace reverse idler shaft? - Defender Source
Old April 13th, 2014, 10:45 AM
Ncmike
1983 series iii stage 1 109
The set screw that holds the reverse Idler shaft in place has sheared off causing the shaft to slide out of its hole. Is there a way to remove the shaft without dropping the gear box? This is on my stage 1 1883
Old April 13th, 2014, 03:17 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Looking at the workshop manual here, it looks like not; you can access it from removing the side panel.
PM me your email and I'll fling the manual over. It's 6mb mind.
Old April 13th, 2014, 03:23 PM
Ncmike
Thanks..my email is braintan@hotmail.com......ive removed side plate and can access it that way but not remove it..i need to drill and tap the set bolt on the rod.......
Old April 13th, 2014, 03:33 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
email inbound
95, ac, idle
idler pulley bearing 300TDI lrna04 Defender Technical Discussions 12 November 18th, 2013 04:19 PM
timing belt idler stud soturi Defender Technical Discussions 4 February 15th, 2012 02:56 PM
How to remove channel to remove seat skins Campbell Defender Technical Discussions 2 October 23rd, 2009 05:47 PM
'97 Serp Idler Monkeyboy Defender Technical Discussions 4 May 15th, 2009 01:39 PM
Part Number for AC Idler Pully mgrgpg Defender Technical Discussions 2 August 4th, 2005 10:07 AM
