Loud squeal/screaching!!!!!!! - Defender Source
Old August 21st, 2015, 11:34 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Coming from under the truck. Started when coming back from Guy Fawkes last year. Happens when going downhill on the road. Then uphill. Then both uphill and downhill. Then all the time after it warms up. If I take my foot off the gas pedal to reduce speed it will go away. But as soon as I increase the speed it comes back.
Just replaced the throwout bearing and the noise was still there after driving the truck for about 20 minutes or so. All the Ujoints on the driveshafts have been replaced as well.
Anybody have any ideas????
Old August 21st, 2015, 11:46 PM
Fan belt?
Old August 21st, 2015, 11:58 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by javelinadave View Post
Fan belt?
And/or pulley bearings.
Old August 22nd, 2015, 12:05 AM
airbornrover
William Skidmore
SIII 109 SW
Fan belt is good. Replaced it within the last year or so.
Old August 22nd, 2015, 12:11 AM
D90Overkill
David Frank
1995 ST #2615
I'm assuming this is occurring in your '94 90, not the 109, and that it's still an original v-belt 3.9? Any chance you feel like removing your belts and rolling your pulleys? I had a similar problem and that was it.
Old August 22nd, 2015, 08:25 AM
airbornrover
William Skidmore
SIII 109 SW
Its the 109. Ill check the pulleys today.
ac
engine squeal and RPM SBrick Defender Technical Discussions 6 October 10th, 2012 11:27 AM
AC compressor clutch squeal artm Defender Technical Discussions 9 June 14th, 2010 04:34 PM
Squeal at 2k RPM. Quimbola Defender Technical Discussions 5 November 18th, 2009 11:10 AM
Cargo door hinges squeal JFD Defender Technical Discussions 1 June 26th, 2009 07:09 PM
new brake squeal nyikaguy Defender Technical Discussions 7 October 30th, 2006 08:56 AM
