Loss of Power with 1994 Land Rover Defender 300tdi - Defender Source
Old November 30th, 2015, 07:21 AM
toggy
Philip Game
1994 Defender 110 300tdi
Hello ! I have a problem with my Defender which I canít seem to solve.
I have loss of power when going up hills and it is also bad when towing, I have to keep changing down and the problem seems to be getting worse.
I have had it serviced, changed the fuel pump and the uplift pump and the local garage canít find any faults with the turbo.
I am currently in Sweden and in general specialist landy garages do not exist so hoping to get some good advice from the enormous Defender expertise back home in the UK. When stationery the engine revs well and appears to show no problems.
On top of this if I try to give it some welly in 5th when it starts to die then the drive seems to disengage and the engine revs up so I de-throttle and change down to 4th and it picks up again. This could be a different problem to the above but must be related.
The vehicle has 155 k on the clock and I am the second owner, last year the timing belt was changed.
Unfortunately my mechanical knowledge is limited and have to rely on those that know.
if anyone on the forum could give me some possibles as to what the problem may be then I shall be extremely grateful. Thanks
Old November 30th, 2015, 07:41 AM
First need to know overall condition of the engine. You need to do a compression test to be sure that there is no "blow-by" of the rings. Also make sure the valves are properly adjusted.
After that you can begin to explore external issues such as fuel delivery, boost, etc.
Old November 30th, 2015, 03:19 PM
toggy
Philip Game
Thanks Bill, very much appreciated, off to get that organised.
Old November 30th, 2015, 03:31 PM
Your first problem sounds like fuel starvation or an air leak in the fuel delivery. Change your fuel filter, if that doesn't fix it start looking for possible air leaks.
Your second problem sounds like a slipping/burnt clutch.
Old December 1st, 2015, 03:23 AM
toggy
Philip Game
Hi Doug, thanks for the advice, both sound good sensible suggestions. Thanks again for the feedback.
1994, 300tdi, defender, land rover, land rover defender, tdi
HS2.8TGV Severe power loss. Air in fuel line? DesertRat Defender Technical Discussions 12 February 24th, 2007 08:35 AM
Total loss of power - now won't crank dnp Defender Technical Discussions 7 February 17th, 2007 10:23 PM
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
Strange loss of power... OCD90 Defender Technical Discussions 3 September 7th, 2004 05:32 PM
Power loss and popping! TwisteD90 Defender Technical Discussions 40 May 30th, 2004 12:45 PM
