LED head lights into Series buckets? - Defender Source
Old February 21st, 2016, 12:47 PM
Ignotus
gene
1960 109, w/200TDI
Does any one know(first hand experience) whether LED headlights are plug and play in the Series headlight buckets? I might have a good deal on some JW Speaker 8700's if they will fit.
Thanks, I'll take my answer on the air!
Gene
1960 109
1960 88 Ignotus
Blog;
Old February 21st, 2016, 01:01 PM
Originally Posted by Ignotus View Post
Does any one know(first hand experience) whether LED headlights are plug and play in the Series headlight buckets? I might have a good deal on some JW Speaker 8700's if they will fit. Thanks, I'll take my answer on the air!
Yes they should fit ... I've seen series running other LED headlights so no reason JW Speaker's would be any different.
ht, lights, series
Rear buckets? TMWTP Defender Technical Discussions 7 May 11th, 2015 12:19 AM
Replacment WIPAC plastic headlamp buckets Chris Velardi Defender Technical Discussions 3 June 22nd, 2014 08:11 PM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 05:34 AM
Coming down like buckets in buckets airbornrover Misc. Chit-Chat 2 August 21st, 2011 10:24 PM
Spring Buckets devinchi Wanted 0 August 9th, 2008 06:19 PM
