Leaking Rear Hub - Defender Source
Old February 28th, 2015, 05:46 PM
RBBailey
RBBailey
1965 IIa
Leaking Rear Hub
Seeping from the rear hub, on the outside of the wheel and hub and cap only. Is this just the seal on the driving member, or something more?
Project:
1965 IIa SWB
Old February 28th, 2015, 06:21 PM
Yes. Just the drive flange.
Old February 28th, 2015, 07:06 PM
RBBailey
RBBailey
1965 IIa
Cool. Thanks.
I have just started using Right Stuff on things like this. It just works.
Project:
1965 IIa SWB
Old February 28th, 2015, 07:08 PM
Try a new cap first. 9/10 times it will fix your leak problem.
Old February 28th, 2015, 07:12 PM
Ignotus
gene
1960 109, w/200TDI
clean it up and tighten the drive member, might just go away. Then go for a drive and see where it starts to come out at, if at all.
Gene
1960 109
1960 88 Ignotus
Blog;
Old February 28th, 2015, 07:29 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Umm the fixing bolts are not very hard & will break if over torqued.
Factory says 28 foot pounds torque.
What plastic caps??
TeriAnn
Old February 28th, 2015, 08:04 PM
Ignotus
gene
1960 109, w/200TDI
What plastic caps??
Didn't see where I said to overtorque them. Some folks don't realize thier bolts are just loose.
Gene
1960 109
1960 88 Ignotus
Blog;
Old March 3rd, 2015, 11:51 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
No but 28 foot pounds doesn't feel like a lot of torque with most socket wrenches. and if you don't know the factory specified torque setting it is easy to overdo it.
"A little is good, more is better and too much is just right"
Personally I'm in the school of removing the drive flange, clean the surfaces, add a bead of form a gasket, torque it down to factory spec, replace the felt seal at the end of the axle with a thin coating of RTV along the edges of the felt seal then replace the galvanized steel dust cap placing a thin coating of RTV around the inside lip.
Scotty insisted that a bead of RTV just inside the dust cover lip keeps leaks going past the felt seal from getting out.
I'm just a believer in if you have to do something, do it completely and be done with it.
BTW, have you decided on what engine to put into your 109?
TeriAnn
Old March 3rd, 2015, 11:54 AM
RBBailey
RBBailey
1965 IIa
...I hope to have time to do this job today... or tomorrow... or......?
Either way, good news is that I finally did seal the valve cover! I had done it on my other engine, but this one was giving me problems.
Project:
1965 IIa SWB
Old March 6th, 2015, 09:50 PM
jgrear
Jason
1973 Series III Diesel 2.25
Leaking hub seal
Don't forget to clean out the axle vent cap on the top of the axle. Supposedly, a clogged vent can make leaky hubs worse. You can remove it to clean it. There's a little ball valve in there you can clean and loosen by soaking in solvent and fiddling with something pointy.
Jason
Old March 6th, 2015, 09:54 PM
FYI I replaced my hub plastic caps with the Series galvanized ones a long time ago based on advise from Pendy.
Mark Kellgren
KM4BOR
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 09:00 AM
rear shock(s) needed, one is leaking hillstrubl Wanted 9 January 5th, 2011 01:03 PM
Rear brake leaking? bjf Defender Technical Discussions 56 March 22nd, 2010 07:54 PM
Leaking rear diff - advices ? JFD Defender Technical Discussions 10 December 7th, 2009 07:30 AM
Hub leaking from center bjf Defender Technical Discussions 18 March 26th, 2009 09:56 AM
