Kodiak Mark IV heater core - Defender Source
Old April 22nd, 2012, 12:11 AM
I seem to have sprung a leak in my heater. In case the core really is bad and I'm not seeing a leak from a hose connection or something, does anyone know who sells replacement heater cores for these?
tia
charles
Originally Posted by pendy
I'm here for the D's
Old April 22nd, 2012, 07:13 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The local shop here has made me new cores for the Kodiak.
Matt Browne
Old April 22nd, 2012, 08:47 AM
Thanks guys. I guess I'll try verify the leak is internal and then pull it.
Old April 22nd, 2012, 09:29 AM
I had mine rebuilt by universal carnegie mfg in PA but it is not clear if they are still in business. 120 bucks for a new core using the tanks from my old one.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 11th, 2014, 11:41 AM
Thanks Dave. I finally pulled it after the cold spell. If I used the heater I just got a oily mist on the windshield
I sent universal carnegie an email.
Old January 11th, 2014, 12:33 PM
Roverx rebuilt the one I bought from him.
Old January 14th, 2014, 09:37 PM
Thanks. I think I'm going to bite the bullet on this one and get it rebuilt. Everything else in the system is in great shape and I'd like to keep it all stock. It's all boxed up and I just need to ship it out.
I do however need to do some thinking about a solution for the 109" heat. I have fresh footwells and want to make the cuts before galvy. It has/had a kodiak mark III iirc and the inside ducting is in pretty rough shape and I do't think I can salvage it. I want to switch to electric based heat, like a ceramic heater for the core, but want to retain the ability to draw in fresh air from outside and have stockish looking ducting on the inside. I am not sure which are the most available, but kind of like the mark IV inside bits. I think the outside housing and motor are refurbishable but haven't looked at it too closely.
Old January 14th, 2014, 09:56 PM
I raise a hand for the venerable shin burner. They are plenty for our climate and they don't need big holes cut into the bulkhead.
Old January 14th, 2014, 10:16 PM
61rover's Avatar
61rover
John Crouse
The Kodiak Mark IV doesn't require any holes to be cut in the bulkhead. It uses the pedal holes on the right side.
Old January 14th, 2014, 10:21 PM
I have been out in the woods with a good shin burner in 15 degree weather and it totally sucked. Kodak had no problems at much lower temps.
Present:
1987 RRC- "Chewy 2"
Past:
Old January 14th, 2014, 10:45 PM
87 D110 (Ruby)
Bam! - it does need the inside pedal box hole enlarged a little but you are basically right.
Old January 14th, 2014, 11:01 PM
Don't go out in the woods in 15 degree weather with a 2A yo. Take the RRC!
Old January 15th, 2014, 01:50 PM
I like that. The venerable old shin burner is so good, you have to buy another vehicle in order to stay warm. That makes about as much sense as a football bat!
Old January 15th, 2014, 01:56 PM
If it's sense you want, stay away from Land-Rover!
In the interest of full disclosure, I am not going to install the shin-burner in my project, even tho it keeps me warm enuf. The new HVAC scenario involves a big PAR blower, a Ford truck heater core and lots and lots of pipes and shyte. A Kodiak heater if Adams were designing it.
Old January 15th, 2014, 10:49 PM
Except I replaced the footwells which came with no holes . Since I am cutting new holes I might as well choose exactly what I want.
Like Jonesy says it would help to enlarge one a little, which I just might do on the 88" while I have it out.
Old January 16th, 2014, 04:29 PM
Enlarging the hole is in the instructions that come with a kodiak
http://www.lrfaq.org/Series/FAQ.S.opt.heaters.html
Old January 16th, 2014, 04:46 PM
61rover's Avatar
61rover
John Crouse
It just depends on which Kodiak you're putting in. The Mark III does require cutting. The Mark IV is completely different and only requires the pedal holes.
I personally think the Mark IV is the most elegant of all the Kodiaks. It's the least disruptive and takes up the least space in the interior.
Old January 16th, 2014, 05:02 PM
I like the original (I think maybe it is mark II). I have one for my 59. It sits above the tunnel cover on the bulkhead when the fuses would be on a defender.
heater
NAS D110 Heater Core Removal Jon_Winningham Defender Technical Discussions 6 January 8th, 2014 11:23 PM
Getting at the heater core Campbell Defender Technical Discussions 24 August 26th, 2013 01:47 AM
WTB/WTT: for 87 RR heater core headdamage Wanted 2 November 17th, 2005 06:14 PM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
Heater core Burke Wanted 1 December 9th, 2004 12:21 AM
