J Nuts (was Steve) - Defender Source
Old February 13th, 2014, 08:20 AM
Chippy
Stephen
1994 Defender
J Nuts (was Steve)
Hullo Gentlefolk,
I am wondering if someone can tell me (with pictures) how I might replace the front hinges on my 94 Defender)
In particular how to replace the bits the screws go into?
Stephen
Old February 13th, 2014, 08:23 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Originally Posted by Chippy View Post
Hullo Gentlefolk,
Stephen
I don't have pics but the nuts are secured in a clip that clips to your bulkhead. Do the bolts come out or just spin? If they just spin, drill them out and get new hardware.
Old February 13th, 2014, 09:55 AM
ezzzzzzz
Mark Garrenton
As stated above, if the screw is just rotating you'll have drill the head out to remove the hinge. There are J nuts fitted into slots in the bulkhead that these hinge screws go into.
Old February 13th, 2014, 10:00 AM
Further to this. you only need to drill the heads off the screws. This lets you remove the hinge and access the nuts. Most of the time, the lower hinge will be rusted and need to be drilled off.
Old February 13th, 2014, 10:05 AM
I would also replace the screws and bits with stainless steel ones.
Welcome to the forum and post up a few pictures of your rig.
Old February 13th, 2014, 09:30 PM
Chippy
Stephen
1994 Defender
Thanks Fellas,
Can I put the new clips in easily from the outside?
I would rather get it sorted before I have the door of as it is my daily ride and full of building tools.
Not to mention Mr Plod may not approve if I drive around without a door while I work things out!
Cheers
Stephen
Old February 13th, 2014, 09:40 PM
ezzzzzzz
Mark Garrenton
Once you've got the old ones out the new ones pop right in from the outside. There's no other option. You'll see it as soon as the hinges are out of the way. It's painfully obvious.
Old February 13th, 2014, 09:50 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Thanks Fellas, Can I put the new clips in easily from the outside? I would rather get it sorted before I have the door of as it is my daily ride and full of building tools. Not to mention Mr Plod may not approve if I drive around without a door while I work things out! Cheers Stephen
You can only put them in from the outside. Once you get the hinge off, you'll see a hole just big enough for 2 fingers to pull the old clip out and pop in a new one. It's tight but you'll figure it out. Just be careful not to let the clip fall in. Buy extra just in case.
'95 RRC LWB Aspen Silver
'86 110 SW Conniston Green - SOLD
'95 D90 ST Beluga Black - SOLD
'96 D1 SE7 Willow Green - SOLD
Stupid Question.....about lug nuts excanuk Defender Technical Discussions 31 July 22nd, 2008 06:38 PM
Quick-release nuts for door tops - can anyone remember these? chittybangbang Defender Technical Discussions 20 May 30th, 2005 10:57 PM
Stock wheels and lug nuts! TwisteD90 For Sale - Parts 3 February 1st, 2005 04:24 PM
Rear spare tire mount - nuts Kimos Wanted 1 December 4th, 2004 08:17 PM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
