intake hose without the MAF - Defender Source
Old November 26th, 2011, 08:46 PM
cdb
Clark Bowen
I'm part way into installing a V8Developments Plug N Play Megasquirt ecu in my 1995 RRC and wanted to know if anyone has done the same to a 3.9 D90 motor.
If so, did you eliminate the MAF and add a K & N in place of the stock air cleaner.
What did you use for the intake hose?
Did the length of hose affect performance?
------ Follow up post added November 26th, 2011 07:20 PM ------
sorry - wrong forum.
2011 RR HSE -
2001 GMC 2500 4wd
air intake hose --molded or flex jack SF Defender Technical Discussions 3 September 24th, 2010 12:30 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
Intake hose from MAF to Plenum ini88 Wanted 3 July 27th, 2007 03:45 PM
Looking for 3" I.D. air intake hose Gkase Defender Technical Discussions 4 September 12th, 2006 10:41 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
