How to test a Series gearbox when it is out of the truck - Defender Source
Old October 30th, 2013, 08:12 PM
cdb
Clark Bowen
Are there some good checks/tests to do to see if a Series 3 gearbox I bought is ok?
Hate to install it and have issues.
2011 RR HSE -
2001 GMC 2500 4wd
Old October 30th, 2013, 09:16 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
a way to do it is move the shifter forks through each gear and rotate the input or output shaft and listen or feel for vibrations, catches, or clunks. You can hook it up to an electric drill to get it to spin a little faster. If there is oil in it, drain it and look for chunks. If you are really gung ho, you can pop off the top cover in short order, be mindful of the detent balls and springs (they like to run around), and look at the gears and synchros. The gears should not be pitted or missing chunks, and the synchros should have little brass rows of ridges on their insides and should not be smooth.
-Rob
series
A Great Read... CDN90 Misc. Chit-Chat 6 December 16th, 2009 12:25 PM
For Sale: 1971 Land Rover Series III Truck Cab, $16k, Scottsdale, AZ azarmadillo For Sale - Vehicles 0 February 13th, 2009 10:18 AM
1999 Discovery Series I chrisvonc For Sale - Vehicles 14 April 11th, 2004 02:15 PM
