Hose connection or termination? - Defender Source
Old February 9th, 2015, 02:06 PM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
This hose most certainly should connect to something, have something on the end of it, or should be terminated with a plug. Which is it?
"I think we are good...its still dripping"
Old February 9th, 2015, 02:28 PM
Check air inlet/carb for connection.
Old February 9th, 2015, 02:29 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Looks to be an old fashion crankcase ventilation into the atmosphere.
Certainly should be either plugged into the air filter box or requires its own filter.
Black Rhino Lives Matter
Old February 9th, 2015, 03:53 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Breather on 2.5 goes to the air intake just prior to the air filter box.
May have been pulled due to overpressure from bad rings/gasket to prevent oil from soaking the air filter and causing the engine to run away. (2.5Td issues)
Old February 9th, 2015, 08:46 PM
Ignotus
gene
1960 109, w/200TDI
2.25? Should be a small male port on the air intake elbow.
Gene
1960 109
1960 88 Ignotus
Blog;
Old February 9th, 2015, 09:55 PM
WildBoar's Avatar
WildBoar
Derek Borror
Yep...2.25 but I don't have the stock air box. Just a small K&N filter directly on top of the carb. With my set up should I plug it or put its own filter on the end?
Old February 9th, 2015, 10:09 PM
Ignotus
gene
1960 109, w/200TDI
It will be internally pressurized. Was part of the early smog reduction efforts a seperate filter will probably get oil soaked. I've seen them replumbed back into the intake, plugged or vented to the rear of the vehicle, far be it for me to advise(esp online) to not put it back in the intake.
Gene
1960 109
1960 88 Ignotus
Blog;
Old February 10th, 2015, 09:03 AM
Just A Number
MP
1984 SIII Lightweight
Here is how mine is plumbed. Not much help possibly due to your set up but just in case you can find some use for it.
Old February 10th, 2015, 10:06 AM
jafir's Avatar
jafir
Jafir Elkurd
I'd think if it normally is connected to the air intake hose, you'd want to replicate that vacuum somehow, or else crankcase pressure might increase and you'll get more oil leaks. This is why PCV is an upgrade over a road draft tube.
Old February 10th, 2015, 12:53 PM
psykokid
Jake
1997 Disco
A catch can would work as well if you are getting any blowby through the hose from the separator on top of the valve cover..
Old February 10th, 2015, 01:57 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks for the suggestions and replies everyone. I now have a plan....
Old February 11th, 2015, 12:48 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
FYI:
The late SIII has a different & unique PCV system - it is called a fixed-orifice system.
I had the same system on my late SIII Lightweight. Here is some info on it:
Old February 12th, 2015, 06:18 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks Jeff!
Fuel Hose...yep hose. wcampbel@nas.edu Defender Technical Discussions 0 January 9th, 2012 05:22 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
Think there is a connection? JohnK Misc. Chit-Chat 2 April 6th, 2005 01:16 AM
140amp alterantor from rover connection - ROCKS! solihul Defender Technical Discussions 5 March 19th, 2005 02:42 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
