Hi Lift Jack External Lockable Mount Suggesstions - Defender Source
Old January 22nd, 2015, 10:58 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
I want to mount my hi lift on the outside of the 109 much like these pictures. I don't have a swing away tire carrier though. Any comments or suggestions? Particularly interested on the hardware anyone has used to lock the jack to the truck in this fashion.
"I think we are good...its still dripping"
Old January 22nd, 2015, 12:50 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
I've seen the set up lack Jeff mentioned before, and I've also seen people drill into their tub to fit one of these: http://www.quadratec.com/products/92...pc3BoCbPDw_wcB
Before installing it though, make sure you REALLY like it there, otherwise you're left with extra holes.
Old January 22nd, 2015, 08:04 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Its easy just buy the warn angle mount. Cut a sheet of aluminum to use as a spreader (if you will). Place them on the interior, drill your holes, mount the brackets. The studs on the brackets have a hole in them so you can use a padlock to keep it in place. Easy peasy.
Old January 22nd, 2015, 09:47 PM
WildBoar's Avatar
WildBoar
Derek Borror
Looks like there are several ways to skin this cat. All good suggestions....thanks everyone. Just wanted to make sure nobody had any bad experience with hanging one of these in the upright position at that location. Looks like it shouldn't cause any problems.
Old January 25th, 2015, 09:18 PM
Alaskantinbender's Avatar
Alaskantinbender
jim
63 series 2A 109 3 door
I used the Hi Lift mount on mine. Just bolted on. The only problem so far is that depending on your spare tire size the rear door wont open all the way.
1995 D90 SW 338/500
1963 S2A 109 3 door
Old January 26th, 2015, 08:27 AM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks Jim!
Old January 26th, 2015, 11:03 AM
curry's Avatar
curry
brandon curry
Series 1 and 110.
I have the same setup as Jim on my IIA. I moved my plate to the right side of the truck and have the Hi-Lift on the left. Works great. Sits perfect on the bumper handle to take the weight.
(just rotate your head 90 to the left)
Old January 26th, 2015, 01:35 PM
WildBoar's Avatar
WildBoar
Derek Borror
Definitely a good idea to let the bumper handle take the downward weight. This seems like the best set up for me. Do you have the ability to lock it to deter theft? I know I have been focused on the ability to lock the jack to the truck, maybe I am just being too over-cautious?
Anyone ever have their externally mounted jack stolen?
Attachment 111988
Old January 26th, 2015, 01:47 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
With my setup I have a lock that attaches the Hi-Lift through one of the holes on the base to the handle on my bumper. Sure somebody could pull a few cotter pins and separate the base from the body, but I'm not thinking thats really a thing. Besides, I think that the winch on the front of my truck would be a better bet for somebody to steal. Undo a few hex bolts and see ya later...
Old January 26th, 2015, 01:57 PM
the rover shop
shayne young
Good to know... WHAt kinda winch, and where do you live..
Old January 26th, 2015, 01:59 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
The kind now attached with some Loctite Red.
Old February 3rd, 2015, 12:56 PM
WildBoar's Avatar
WildBoar
Derek Borror
Well, here is the end result. Decided to use the standard Hi-Lift jack mounting brackets. The wing nuts on the mounting brackets provide the ability to put a lock on either them. All the jack weight is literally on the bumper pull handle. I decided to mount the second bracket up further up on the roof to spread out the attachment points. I hope the concourse judges don't ding me on the extra holes in the roof (joke of course). I figure the roof rack will get ripped off before the jack catches on anything.
ID:	112686   Click image for larger version
Old February 3rd, 2015, 12:59 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
Very nice
Old February 3rd, 2015, 04:26 PM
Alaskantinbender
jim
That looks great.
What about the door mounted spare and jack clearance issue?
1995 D90 SW 338/500
1963 S2A 109 3 door
Old February 3rd, 2015, 08:38 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks! Right, there is a small clearance issue with the spare and the door. It will open up to about 90 degrees which keeps it functional but not ideal. Eventually I would like to get a swing away spare carrier to get the weight of that big tire off the rear door anyway.
Old February 3rd, 2015, 08:54 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Nice work. If you have a cover put it on the jack. The back always accumulates tons of grit
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old February 3rd, 2015, 09:12 PM
WildBoar's Avatar
WildBoar
Derek Borror
Great advice. Looking online for one now.
Old February 3rd, 2015, 09:25 PM
airbornrover
William Skidmore
SIII 109 SW
That thing doesnt need a cover just pour some Coke, wd40, or just piss on it every so often. It'll be just fine.
Old February 7th, 2015, 02:42 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Since one of the pictures of your examples is my truck I suppose I should reply.
I just went out and took some new and better detail pictures of how I mounted my hi-lift jack. I added those to my web page along with additional text. The jack mount has been on the truck for 18 years now and has been on a lot of long off road trips under just about every weather condition without any issue beyond needing to occasionally lube the lock.
If you want to see how mine is mounted the pictures are near the bottom of the web page:
http://www.expeditionlandrover.info/GRdetail1.htm
The pictures have just been uploaded so may take a couple house to get to your local server.
TeriAnn
Old February 7th, 2015, 06:49 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks TeriAnn. I will definitely take a look at your new pictures.
Originally Posted by TeriAnn View Post
Since one of the pictures of your examples is my truck I suppose I should reply. I just went out and took some new and better detail pictures of how I mounted my hi-lift jack. I added those to my web page along with additional text. The jack mount has been on the truck for 18 years now and has been on a lot of long off road trips under just about every weather condition without any issue beyond needing to occasionally lube the lock. If you want to see how mine is mounted the pictures are near the bottom of the web page: http://www.expeditionlandrover.info/GRdetail1.htm The pictures have just been uploaded so may take a couple house to get to your local server.
ac, mount
Spare Tire Hi Lift Jack Mount Jpayne For Sale - Parts 100 September 22nd, 2014 08:57 AM
Best way to rear mount a Hi-Lift Jack? silverlight Defender Technical Discussions 23 August 1st, 2013 10:28 AM
Hi lift jack mount prototype Jpayne Misc. Chit-Chat 14 November 26th, 2011 10:23 PM
Hi-Lift Jack Spare Wheel Mount nikojo Defender Technical Discussions 13 January 22nd, 2011 01:52 AM
Rear Receiver Hi-Lift Jack Mount Wolf Fabrication For Sale - Parts 16 April 6th, 2009 05:46 PM
» Defender Registry
Green Mile
Jdc0430
D
drsmiley
Add your Defender
