Help Needed - Defender Source
Old September 8th, 2015, 09:04 AM
Scotty's Avatar
Scotty
Scotty
1963 Series II A 88
Help Needed
Hello to fellow Lady folk.. I do need some help, How do I I.D. which motor I have, the original color, which trans I have & so On? Which is the best parts source and which service or restoration guide & parts books should I get?
Thank you
Scotty
ID:	129109   Click image for larger version
ID:	129111   Click image for larger version
ID:	129113   Click image for larger version
ID:	129115   Click image for larger version
ID:	129118   Click image for larger version
Old September 8th, 2015, 09:10 AM
Scotty's Avatar
Scotty
Scotty
1963 Series II A 88
More pic's
Old September 8th, 2015, 09:23 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
You can tell you have a S2 truck from the headlights and dash. Look up lrfaq.org They have a data base of serial numbers to help a person figure what truck you have. The parts catalogue for your truck are easy to find either pdf or hardcopy. Serial number for the tranny should be looking from the highest point on the transmission itself looking down to between the housing surface and the forward section of the transfer case. TeriAnn's Expedition Land Rover site , I believe tells you what the serial number on the engine head means. Cant remember if they stamped the number 7 in the same place as they stamped the number 8 on later engine heads.
Might want to also join some of the local forums in your area as one or two are some of the oldest clubs/groups at the very least have people that have owned rovers since the 60's and and join the mendo email list, most members on that email list live in California.
Did you find a data plate on the bulkhead? Not uncommon for engines and trannys to be swapped out. Someone else can chime in but I think the orginal color for rover engines is light green or robins egg blue range.
From the fuzzy pic of your doors you look like you have S2 door hinges.
Old September 8th, 2015, 09:29 AM
Scotty's Avatar
Scotty
Scotty
1963 Series II A 88
William thank you for your time, and advice I really appreciate it!
Scotty
Old September 8th, 2015, 09:31 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You have the early low compression 2.25 petrol powered Land Rover engine mated to a non-syncro 4 speed transmission.
RDavisinVA
Old September 8th, 2015, 09:32 AM
Scotty's Avatar
Scotty
Scotty
1963 Series II A 88
Thank you rdavisinva, so that would be the 7:1?
Old September 8th, 2015, 09:44 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Looks like it by the cylinder head casting which is drilled for the early choke warning light sender and doesn't have the 8-1 raised ridge.
RDavisinVA
Old September 8th, 2015, 10:58 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Here's a parts catalog that should tide you over. Unfortunately it wasn't scanned with OCR so you can't search it.
https://www.scribd.com/doc/34174887/...2-2A-Parts-Cat
Owner's Manual
https://www.scribd.com/doc/101420884...Owner-s-Manual
I haven't found the SIIa factory workshop manual online (I'm sure it's out there) but here's one you can get by with until you find it. It's the first Rover manual I ever bought.
https://www.scribd.com/doc/47495225/Rover-Manual
------ Follow up post added September 8th, 2015 10:59 AM ------
Owner's Manual
I'm guessing the original color was red, or else someone did a very thorough job repainting it.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 8th, 2015, 11:50 AM
Scotty's Avatar
Scotty
Scotty
1963 Series II A 88
Right on guys thank you! Antichrist thank you for the references!
quick help needed 4.2 oil lines Abrooks Defender Technical Discussions 8 February 10th, 2006 02:38 PM
ARB Problem : HELP needed Jay Defender Technical Discussions 5 January 15th, 2006 06:09 PM
A few problems - Help needed arbik Defender Technical Discussions 10 April 14th, 2005 04:54 PM
d90 makes me ask this needed computer help question paulb Misc. Chit-Chat 5 April 7th, 2005 04:01 PM
Help Needed asdaly3 Misc. Chit-Chat 10 April 16th, 2004 12:25 AM
