Help Identify Part - Defender Source
Old June 23rd, 2011, 08:12 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Help Identify Part
- LR 110
- 2.25 Diesel
Is there supposed to be a hose that connects to this part? (At the end of my finger)
I was spinning the fan tonight and heard a pumping noise coming out of this connection. Never noticed it before. Other end of hose goes to the radiator expansion tank. Truck has always ran fine.
Thanks for the help.
-Neil
Old June 23rd, 2011, 08:41 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Mine is configured a bit different, but there is no hose coming off of one fitting like yours.
Not sure if that is good or bad though
Old June 27th, 2011, 12:49 PM
Neil
Its a vacuum pump for the brake booster. No idea why yours is hooked to the cooling system.
Line up the two marks on the pulley and pump body and then fill it with 20w50. There should b e a fill plug on it somewhere.
part
Identify this part Manimal Defender Technical Discussions 1 January 12th, 2010 02:53 AM
part #'s for a 94 jimmy salmon Defender Technical Discussions 3 March 27th, 2006 10:10 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
