gas in engine 1967 2A - Defender Source
Old February 11th, 2011, 10:38 PM
kjva
Ken Jackson
1985 110 Wagon
My 2A wagon was running very rough, I took of the hose on top of the carb to check the choke was not stuck, is was not but then engine oil squirted from the breather tube on top of the rocker cover. The oil smelt of gas and the oil on the dip stick was very thin also smelling of gas. Any ideas before I tear it down
Old February 11th, 2011, 11:42 PM
floatflyer
Bryan Krill
'95 D90 wagon
check your mechanical fuel pump, it may have ruptured its diaphargm and is pumping gas into the crankcase.
Old February 12th, 2011, 07:25 AM
kjva
Ken Jackson
1985 110 Wagon
Thanks I will check, would never have thought of that. Did a compression test and it was on the low side but all cylinders the same. The Rover smokes heavily which is why I thought the choke was stuck
Old February 12th, 2011, 10:52 PM
running rich. check the carb float isn't leaking.
Old February 13th, 2011, 09:14 AM
kjva
Ken Jackson
1985 110 Wagon
It smokes like a train rather than running rich. If the float was stuck that would not explain the gas in the engine oil. Hoping to pull the fuel pump off today
Old February 20th, 2011, 07:52 AM
kjva
Ken Jackson
1985 110 Wagon
Just put in a new fuel pump and the problem was solved. Cost of the pump from Atlantic British was the same as one from the Uk.
Old February 20th, 2011, 10:16 AM
floatflyer
Bryan Krill
'95 D90 wagon
glad that solved your problem!
Old February 20th, 2011, 11:16 AM
BTW the smoke was because the gas increased the oil level so it started burning oil. Happens on my 1994 NAS D90 when the computer gets wet and sticks on the injectors. Some things never change.
Old February 21st, 2011, 03:03 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
You'll be wanting to change your engine oil pretty quickly.
Mike Hammond
Old February 23rd, 2011, 07:14 PM
kjva
Ken Jackson
1985 110 Wagon
Changed the oil when I put the new pump in, will do it again after a few miles, waiting for it to warm up, the suirrel cage heater renders the 2A Wagon a mild weather vehicle
engine, gas
2.25 / 2.5 gas engine for 110 kjva Wanted 6 February 3rd, 2011 07:01 PM
