galvanizing finish - Defender Source
Old June 6th, 2012, 12:17 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
galvanizing finish
If I get steel hot dipped that has been blasted and is rough will it have a different finish than steel that is 'normal' and smooth?
I cleaned some of my stuff myself but had some blasted, now I'm a bit concerned that they will end up with different finishes after galvanizing. Not really a big deal, but if it will be very different I'd rather just spend a little and have the rest blasted.
Old June 6th, 2012, 12:26 PM
yeah, clean smooth metal comes out much nicer. I had a some roughly blasted stuff galvanized and I was really glad it wasnt going to show. If it had been for cappings or something exposed I would have been disappointed. I've heard you can ask for a different spec (i.e. architectural) but some certain plants might only offer a particular spec and might not be prepared to process parts for a particular aesthetic finish.
Old June 6th, 2012, 12:52 PM
texrover's Avatar
texrover
Jason
I was wondering why I see differences in the finish of galvenized pieces
What's the prep required for pieces that are already galvenized like body cappings? Should you media blast of them first or something else?
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old June 6th, 2012, 02:00 PM
D90user's Avatar
D90user
steve
Jim- what kind of finish difference was it? If two pieces were next to each other would the difference be obvious?
If so... for the stuff I already have rough blasted what's my best solution? Should I sand it with a fine grit... Or ???
Old June 6th, 2012, 04:16 PM
The difference is super obvious. Galv over rough looks like a cast part. Over clear,rolled steel it looks like beautiful, smooth, flaky, rover chrome.
I've never prepped a rough part for nice galv, but I bet sanding it as smooth as possible is the answer.
galvanizing
Falon Nameplate Finish 61rover Defender Technical Discussions 12 November 30th, 2011 10:13 PM
Galvanizing the bulkhead D90user Series Technical Discussions 16 September 30th, 2010 10:13 AM
Galvanizing the bulkhead? crobinson Defender Technical Discussions 2 December 30th, 2005 01:34 PM
Finish the sentence javelinadave Misc. Chit-Chat 10 March 22nd, 2005 10:27 PM
galvanizing questions kit Defender Technical Discussions 4 October 21st, 2003 10:31 AM
