Galvanizing door tops - Defender Source
Old July 24th, 2015, 12:07 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So im ripping into my Series 2A.... taking everything apart getting read for media blast, galvanziing, paint powder coat etc.
I want to galvanize the door frames. I noticed the skins on the front door tops are steel, and a bit tougher to pry off than the Aluminum skins on the rest of the door frames.
If i want to galvanize these door tops do i have to remove the skins first? No doubt there is some rust under them between the frame and the skins. Just wast sure what the standard procedure is here.
Any reason why these are steel and the others aluminum? Is that original or perhaps these were replaced once with cheaper steel versions?
Old July 24th, 2015, 12:48 PM
87 D110 (Ruby)
yep - de skin the doors - and then take the frames to galvey bloke.
Old July 24th, 2015, 01:35 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Are the skins on the door tops normally steel or do you think they have been replaced at one time? Thinking I'll bend new ones up out of aluminum
Old July 24th, 2015, 01:41 PM
why not upgrade to aluminum defender door tops ?
Old July 24th, 2015, 02:10 PM
Tops
Rocky Mountain Products, Parabolic Springs, Shackle Kits, Shock Absorber Kits
FRONT DOOR TOPS + PARTS
Old July 24th, 2015, 02:44 PM
bossman429's Avatar
bossman429
Adrian
1988 90
The skins are aluminum. Its easier to carefully deskin them that it would be to make new ones.
if you want to keep it original looking galv is the way to go, but if you dont mind, then the Rocky mountain, or a set of ExMOD would be decent an alternative.
-Jeff
Ok - then these were deff replaced at one time. The rest of the skins are all alum but on both front doors the tops are skinned in steel
Doug - will the defender tops fit these doors? Those show 84-present. Truck is a 67 IIa
no need to buy new, the frames are in good shape. I'm going to be stripping and galvanizing alot of stuff so it would make sense to just "freshen" these up instead of replacing.
Old July 24th, 2015, 03:54 PM
Originally Posted by bossman429 View Post
Ok - then these were deff replaced at one time. The rest of the skins are all alum but on both front doors the tops are skinned in steel Doug - will the defender tops fit these doors? Those show 84-present. Truck is a 67 IIa no need to buy new, the frames are in good shape. I'm going to be stripping and galvanizing alot of stuff so it would make sense to just "freshen" these up instead of replacing.
Yup they will.
Old July 26th, 2015, 08:40 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I bougth the rocky mountain tops for my iia in 2011. One of my best purchases to date.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old July 26th, 2015, 08:58 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Good to here. I'm going to go this route
Old August 1st, 2015, 05:11 AM
Jim-ME
Jim Ecker
1964 Series 2/2a bitsa
I'll second the RM door tops. Good choice
Jim
Old August 1st, 2015, 07:00 AM
71exmod
Bob
69 SIIA Bugeye
tried to buy some used ones, payed a good price but was sent some broken ones which were not advertised as such.
door, door tops, galvanizing, top
Pre Summer Exmoor Trim USA Top Sale (Mesh UV Tops, Surrey Tops, Bimini Tops) ExmoorTrimUSA The Vendors Loft 6 June 9th, 2017 04:26 PM
Bulkhead T/door post galvanizing question lordhelemt Defender Technical Discussions 14 January 22nd, 2014 08:38 PM
Badger Soft top - Proper Storage - Full Soft Tops and other tops rijosho Defender Technical Discussions 10 August 4th, 2010 12:31 PM
? about Door Tops and Door bjp Defender Technical Discussions 8 October 30th, 2008 05:28 PM
Soft Top Door Tops, Door Panels Bozman For Sale - Parts 10 October 31st, 2007 11:19 AM
