Fuel Sender and Unknown Hose - Defender Source
Old May 6th, 2012, 07:46 PM
texrover's Avatar
texrover
Jason
Refitted my newly cleaned fuel tank, and when I went to clean up the sender I realized the brush i was using had Kroil on it which removed much of the brass plating. Should this be a serious issue?
Also, when refitting the tank, I found a hose that runs across the outrigger, then joins with an elbow to a continuous loop that runs up the side back down to another elbow and again down the outrigger. I didn't find it in the workshop manual; the elbow looks like something for a PCV and the hose is about 1/4" in diameter.
Any ideas as to what it is? Is it emission related?
Thx
Old May 7th, 2012, 05:39 PM
If it is a north american truck, emissions makes sense although I have never seen one with all that stuff hooked up. If the sender still reads in a linear fashion without shorts it should be fine. No big deal to swap it later if it does not as I believe you can get to it with the tank in situ from under the seat.
Old May 8th, 2012, 12:04 AM
texrover's Avatar
texrover
Jason
thanks ninja
in NOLA this week so going to drop by George's and pick up a new sender to put on the shelf a long with a few other tidbits
fuel
