forward face rear bench brackets and belt routing - Defender Source
Old March 15th, 2011, 05:34 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I just noticed that my D-90's rear seat does not stay locked in place when in the 'sitting' position. I do have all the correct brackets but it looks like whomever installed the rear seat botched the job. I'm also thinking that the routing of the seatbelt is incorrect.
I'm not sure if the seat is mounted 2-3 inches too far forward or if the 'catch' brackets on the sides of the tub are in the wrong position.
Also, please tell me that the seatbelts should not be routed through the tub brackets as seen in the attached pictures...that just does not seem right either.
Any thoughts?
ID:	36957   Click image for larger version
Old March 15th, 2011, 05:54 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Seat belt should not be through there.
The post on the seat will lock it into the bracket when you push the lever back.
If you do a search on the forums or the site, someone posted a PDF with the measurements at some point in time.
Can you shoot a picture of your front brackets? You look off enough that the front brackets may be mounted backwards.
Can't believe how many people mount these seats wrong...mine was as well and had to have my local shop fix it...
Given they are a weird design...but come one...google an install manual already!!
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old March 15th, 2011, 06:08 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
The front brackets are correct. I think I might have figured out what's going on. The rear brackets are not installed correctly. It looks like whomever did the install, mounted the brackets too far forward- even looks like they cut out part of the tub support to do it. When I compare this location with the location shown in the install instructions, I can see that they simply installed the brackets in the wrong spot.
In the attached photo, you can see the outside of the rear tub brackets and where they cut out the tub support. I cant believe that they went through all the trouble and still didn't get it right.
Old March 15th, 2011, 09:35 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
rear ST setup
See photos. The wheel well pictures are of the driver side. Notice the location behind the tub rib. Also the location of the seat belt bolt. I included an interior shot showing the seat belt bolt location. The last one shows the way the bracket engages the seat when the seat back is locked in position.
ID:	36974   Click image for larger version
ID:	36976   Click image for larger version
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old March 15th, 2011, 10:02 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
Thanks for the pics. They confirmed that my brackets were not installed correctly....another thing to fix!
ac, bench, bracket, rack
Bench Seat & Seat Belt Bracket Feeler jefhuf For Sale - Parts 35 August 30th, 2010 11:01 PM
Rear Seat Belt Brackets founD90 Wanted 21 August 19th, 2010 09:25 PM
forwar facing bench brackets only jack SF For Sale - Parts 16 March 20th, 2010 06:10 AM
Rear bench seat for d90 ST model budz For Sale - Parts 4 December 8th, 2008 01:12 PM
Rear Seat Belt Brackets zed111 Defender Technical Discussions 11 August 6th, 2007 02:45 PM
