flywheel removal - Defender Source
Old June 20th, 2010, 08:02 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
flywheel removal
Is there some trick? Green bible only says remove bolts and remove flywheel. Do I need a puller or something because it is pretty solid in there. Bolts are out.
Thanks.
'98 D1
Old June 20th, 2010, 08:32 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
No trick. Should come right off.
Old June 20th, 2010, 08:55 AM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
Sometimes they are on there real good. It's nice to have an earlier style flywheel housing because you can use the timing opening for access for a pry bar. I see that you have a later style, which make it a bit more difficult to pry the flywheel out. You could drill a small hole on the back side to tap it with a shaft or screwdriver. The hole can be filled with a shallow bolt screwed into the hole.
Sew on and sew forth...
Old June 20th, 2010, 09:44 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
I know it is a machined surface, can use a block of wood against the face with a hammer to get it to break free? I used a dead blow hammer but tried not to hit it too hard b/c I don't want to mess up the face.
'98 D1
Old June 20th, 2010, 11:08 AM
i just hit with the dead blow, usually works fine. Watch yer feet.
Old June 20th, 2010, 11:53 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
You can also remove the starter and access the flywheel for 'rapping' that way.
Old June 24th, 2010, 06:38 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Never had a problem taking mine off, just came off after taking the bolts off.
Robert Deniro
Old June 28th, 2010, 11:59 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
It came off with some hammer work and a block of wood.
Follow-up question. I need to replace the rear main seal and was told I need to pull the entire engine. Is this true? I feel as though I am headed towards Shipfitter's disease.
'98 D1
Old July 2nd, 2010, 03:49 PM
galen if you've got the trans out you can do it with the engine in the car. probably eaiser to do with the engine upside down on a bench, but certainly possible with it still in situ.
Old July 6th, 2010, 07:56 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
Someone told me it is near impossible in the vehicle. I pulled the front fenders in anticipation of pulling the motor. I REALLY do not want to pull the engine unless I have to.
Not having a garage sucks.
'98 D1
Old July 8th, 2010, 08:00 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
It's scary how fast you can tear apart one of these things.
ID:	29178   Click image for larger version
'98 D1
Old July 8th, 2010, 09:19 AM
well, you've already gone this far, and the trans is out, so it is just two more bolts to yank the engine. then you can take some time and repaint the chassis and firewall. the engine will be easier to work on upside down and out of the car.
Old July 8th, 2010, 11:00 PM
Agreed.
Old July 9th, 2010, 11:39 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
I hate asking stupid questions but this is a good time for one. This is more that I have ever done to a vehicle. Can I turn over the engine and work on it? Won't that hurt anything? Obviously, I plan to drain it anyway for a fluid change.
'98 D1
wheel
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
