firewall rust - Defender Source
Old June 9th, 2015, 07:39 PM
alecbeard
Alec Beard
1972 Series III
firewall rust
You know the problem: where steel meets aluminum. I have a bit of rust in the corners working from the inside out on a 1972 series. I'm wondering what people do to stop it.
Should it down a bit and put on some POR 15 or other rust-proof paint? I'm just afraid that unless I get rid of all the rust, it will keep spreading. And if I get rid of all the rust I will have holes in my floor. If that's the best option, how would you patch the holes?
Thanks in advance. I just bought a new rover and am a little worried about keeping it nice.
Old June 9th, 2015, 08:30 PM
Ignotus
gene
1960 109, w/200TDI
Depends on how bad it is. There are complete replacement footwells, cut the old one out and weld in a new one. No aluminum in the bulkhead.
Gene
1960 109
1960 88 Ignotus
Blog;
Old June 9th, 2015, 08:58 PM
alecbeard
Alec Beard
1972 Series III
It's not too bad I don't think. If I cut out all the rust, I would have a 6"x2" hole maybe. Problem is, I'm not a great welder, and welding two different metals is tough, right? Any other options?
Old June 10th, 2015, 09:29 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
The bulkhead is all steel, welding should be no problem.
Old June 10th, 2015, 11:30 AM
Contractor's Avatar
Contractor
Will
1969 IIA
Post a picture.
If all the rust you have only creates a 6" x 2" hole, consider yourself lucky.
That is probably a $50-$100 repair if you have a shop do it.
Old June 10th, 2015, 05:30 PM
alecbeard
Alec Beard
1972 Series III
But the body is aluminum. Where they meet is where the rust is
------ Follow up post added June 10th, 2015 03:31 PM ------
Originally Posted by Contractor View Post
Post a picture.
Thanks. I'll try to take a pic. Yeah I'm probably being overly protective, but I just don't want to have to replace the entire bulkhead one day. That sounds like a real job
Old June 10th, 2015, 07:11 PM
Lemonhead
TB
1997 D90 SW
Would have to see pic to get better idea but I've had a lot of success patching holes with Por 15 soaked fiberglass. Dries rock hard and can hardly knock down the high spots with a grinder.
Key is you typically have to get to both sides to do it "right".
Yes - "right" would be welding or replacing but depending on where the issue is - this is a quick durable (and so far permanent) fix for my needs.
Old June 10th, 2015, 07:49 PM
Pictures?
fire
Rust - firewall or footwell DMSLongLake Defender Technical Discussions 18 June 12th, 2012 01:34 PM
To rust, or not to rust ? RBees Misc. Chit-Chat 10 May 8th, 2008 10:40 AM
Bulkhead/Firewall for Series IIA Coiler Wanted 7 July 28th, 2006 02:52 PM
Galvanized Firewall kit Defender Technical Discussions 3 February 20th, 2004 10:34 AM
