Finding Series Brake Fluid in NOVA - Defender Source
Old November 14th, 2012, 12:35 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
Is anybody able to find Castrol LMA or Lucas Girling (not sure of the designation) brake fluid for their Series in Northern Virginia?
My local places like Olympus, Fairfax Auto, and Advance do not have it.
Any help's appreciated.
Old November 14th, 2012, 12:41 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Amazon is your friend. Same problem here in WA.
1970 SIIA 88, Sold
I ended up having to order from british pacific. Note GTLMA has changed formulas so I don't know if that is a good or bad thing.
Old November 14th, 2012, 01:05 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I bought a couple of small containers (pints) from the FFX Auto on Willard in Chantilly not too long ago. You may want to give them a call as they had a whole shelf...just annoyed me that they did not have the quarts!
Old November 14th, 2012, 02:20 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
AHA! You're the guy who got the last ones at Fairfax Auto in Chantilly! Thanks to all, BTW.
All local stores are now saying they no longer stock it.
What Lucas Girling fluid works? DOT 3 or DOT 4?
I guess I'll be looking at Amazon.
Took me near forever and a day to find the oil filters for the Isuzu 4JB1T engine, but I finally tracked them down at WIX...surprised to have this problem with brake fluid!
Old November 16th, 2012, 08:11 AM
LRover's Avatar
LRover
J. Michael McCaig
My local Advance Auto Parts stocks Castrol LMA in quarts.
Old November 16th, 2012, 10:18 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
Thanks all. 64oz on the way from Amazon! I'm hoping even with Land Rovers that will last a while.
Old November 18th, 2012, 09:23 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Pep Boys. At least they carried Castrol a short time ago.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 18th, 2012, 10:59 AM
giftshopduane
Chris luciano
72 Series 3 88"
Just curious..
Why Lucas or Castrol LMA? Why not Wilwood, Motul or Mobil 1? ATE, Brembo hell even the cheap big bottle off the shelf at Wally's will work in a Series. Just practice proper brake system maintenance habits, bleed and or flush once a year. LMA has a lower absorption rate of water than others thus raising the boiling point therefore lessening the likelihood of your fluid boiling and introducing air and effectively weakening your braking ability. I'd be the first one to admit I'd like to see a Series truck put through its paces enough to boil the brake fluid. As far as corrosion goes, properly bleed your brakes once a year or every oil change and you'll introduce enough fresh fluid into the relatively small hydraulic system of a Series truck to keep the water percentage down.
But then again it all comes down to habit..
Old November 20th, 2012, 01:56 PM
LRover's Avatar
LRover
J. Michael McCaig
For years the rubber seals in the Series Rovers' brake system was made from natural rubber and may still be. Anything other than Castrol Girling would turn the seals to mush after a while.
Old November 20th, 2012, 02:10 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Yes natural rubber seals is what I have read. Loaded up with Castrol for my Series years ago.
MUDSUX
Old November 20th, 2012, 02:34 PM
My understanding is it has a limited shelf life though (absorbs moisture) so multiple smaller bottles are better over a larger one that sits half used for a long time.
Originally Posted by pendy
I'm here for the D's
Old November 20th, 2012, 04:51 PM
Cherrydale Auto Parts in Arlington
Old November 21st, 2012, 07:06 AM
Antichrist's Avatar
Antichrist
Tom Rowe
FWIW, Castrol brake fluid is synthetic and has been for a good number of years. They just started actually stating it on the label a few years ago. I was curious when I noticed the change in the label so gave Castrol a ring.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 27th, 2012, 11:43 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Believe it or else...Edwards General Store in Unionville. 5 qts left over from who knows when.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old November 30th, 2012, 11:18 AM
carlosz's Avatar
carlosz
Carlos
Dot 4 will work, I have located valvoline and generic in syntethic form.. indeed comes down to boiling point and water absorbtion (hygroscopic)...
Wet boiling point defined as 3.7% water by volume.
Boiling points for common braking fluids ,
Dry boiling point Wet boiling point
DOT 3 205 C (401 F) 140 C (284 F)
DOT 4 230 C (446 F) 155 C (311 F)
DOT 5 260 C (500 F) 180 C (356 F)
DOT 5.1 270 C (518 F ) 190 C (374 F)
brake, nova, series
Series I II IIa III Heystee disc brake conversion kit kullberg Series Technical Discussions 8 June 14th, 2012 03:42 PM
'71 Series IIa - $6,500 Winston-Rover For Sale - Vehicles 15 August 25th, 2009 12:43 PM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
