EP 90 US Equivalent?? - Defender Source
Old May 27th, 2016, 04:00 PM
Honestdon
Don
1967
I can't seem to find EP90 or Hypoid 90 for my 67 Series 2a. Is there a US equivalent? Thanks
Old May 27th, 2016, 04:56 PM
Any 90wt (75w-90, 80w-90 etc) gear oil will be fine.
-Jeff
Except you want to use a GL-4 spec not a GL-5 spec. GL-5 eats the yellow metal in the transmission.
Old May 27th, 2016, 05:06 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You must have a walmart near you? Lube king 2 gallon $21 90w gl4
I just got 6 2 gallon cans from TSC for $16 a can
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 27th, 2016, 09:47 PM
Honestdon
Don
1967
For the diffs also?
Old May 27th, 2016, 10:03 PM
Contractor's Avatar
Contractor
Will
1969 IIA
I buy it from Car Quest.
Straight up 90 Weight GL4.
Here is a link to the part number, my local stores carry it all the time.
CARQUEST Service Lines Catalog - Supplement - 0111
Second page, bottom left…….Bravo EP 90 for a part number.
Old May 27th, 2016, 10:07 PM
Any old gear oil for the diffs and transfer case. A GL4 oil for the gear box or an engine oil would do. The problem with gear oil is not white metal corrosion but damage to synchros.
Old June 7th, 2016, 09:42 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
It's like $12 a gallon for GL-1 Gear oil at NAPA. Last I checked GL-4 was far less corrosive than GL-5 but still had corrosive properties.
D90 owners manual chiton equivalent Dirt Defender Technical Discussions 5 January 11th, 2011 02:00 PM
Need an ECU... looking for the ECU out of a 95 Disco or equivalent IPSC_GUY Wanted 7 February 16th, 2010 04:36 PM
Rangey equivalent of D-90 Source? Method PHX Misc. Chit-Chat 4 February 6th, 2006 12:37 PM
D-90.com equivalent for Range Rover? Method PHX Misc. Chit-Chat 3 December 9th, 2005 11:49 PM
hylosil equivalent 48vphantom Defender Technical Discussions 2 February 8th, 2005 09:54 AM
