Engine Rebuild - now times off the timing mark - Defender Source
Old January 31st, 2011, 02:52 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
I just rebuilt my engine. It runs. But, when I tune it by ear, the timing is an inch off the timing marks (appears way too far advanced). If I tune it back to the marks, the engine will not run or start.
What could be the cause of this? (ie: How do I fix it?)
It runs fine (as far as I know) tuned this way - it just just not seem right.
Firemanshort
1980 Stage One 109
Sterling, VA
Old January 31st, 2011, 05:14 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Sounds like the dist is off by a tooth or so.
Daniel
Old February 1st, 2011, 08:23 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
If the distributor drive was off by a tooth or so you would simply have to turn the distributor a little farther to get the timing where it should be, but that shouldn't change the sweet spot for timing the motor.
Is it possible that the cam timing is off by a tooth?
Old February 1st, 2011, 10:37 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Im not familiar with the older v8s. What are the marks on the crank pulley? Are there multiple marks, and if so which mark are you using for timing? An inch advanced from 0 tdc doesn't sound crazy off to me.
I'm sure someone who knows better than I will chime in.
Daniel
Old February 1st, 2011, 10:47 AM
confirm that TDC on the pulley is actually TDC
Old February 1st, 2011, 12:03 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
What Ren Ching said. Be ware that 3.5s like to run with far more advance than the book would have you believe.
engine, rebuild
Engine won't start. Timing chain maybe? ini88 Defender Technical Discussions 12 December 30th, 2010 10:56 PM
Engine Rebuild - How much? ipgregory Defender Technical Discussions 10 July 1st, 2009 12:14 AM
