Early series door pillar captive nut access. - Defender Source
Old December 9th, 2014, 09:34 PM
asetliff's Avatar
asetliff
Adam Setliff
2A 109 Four Door 07 RRSC
2a 109.
I need to figure out how to mount my upper front door hinge back on. I ordered new captive nuts and when I took the hinge off I discovered that previous repairs failed. I can't tell what's behind the two holes but I don't have the square hole that the captive nuts slide in.
I'm stumped and out of ideas without cutting something open.
Old December 9th, 2014, 09:47 PM
Greg S
Greg Sutfin
1986 90
Get a file and make the hole square or install a nut-sert (rivnut).
Old December 10th, 2014, 07:38 AM
Behind the two holes is a captive nut plate. It is held in place with a small bit of metal that lets it move around a bit. When you adjust the door you move the upper hinge until it's in a happy place then you tighten the hinge bolts. The proper repair involves opening up this area, derusting, and replacing the nut plate.
Paul has what you need for the repairs:
http://www.pegasusparts.co.uk/oursho...0-to-1967.html
You're looking for PSK 3138 and PSK 3139. He has the other sections to repair what you cut out here:
http://www.pegasusparts.co.uk/oursho...er-models.html
PS just checked and it says out of stock on those bits, but give Paul a shout and tell him what you need and he will make it for you. Remember it's just one guy behind the website, so you may have to be patient.
Your other option is a refurbished BH from Ashtree:
http://www.ashtreelandrover.com/index.html
Old December 10th, 2014, 09:02 AM
asetliff's Avatar
asetliff
Adam Setliff
I would open up the area in between but I don't think it's much material to work with from the previous repairs.
When I took the hinge off the plate behind the pillar just fell off as it was a home made piece of metal with two nuts on each side. The cage was mangled. I need to make another place and fish it in there but the mangled cage is preventing that.
Does the riv nut require a perfect hole or will it expand? It's body filler around my holes so I don't know how strong it is.
Old December 10th, 2014, 09:23 AM
The handwriting is on the wall, my friend.
Old December 10th, 2014, 09:49 AM
While pictures would help, I think I have the same awful feeling as Bill in saying that this is just the tip of the rusty "time for a full rebuild bulkhead" iceberg
Old December 10th, 2014, 10:30 AM
toad's Avatar
toad
Cutter
Yeah this sounds like you've reached the end of the patches and hack express line.
Old December 10th, 2014, 11:54 AM
you should be able to modify the pillar to use the later style captive nuts that clip over the edge of the metal
Old December 10th, 2014, 12:25 PM
pn mrc2178
Old December 10th, 2014, 12:36 PM
Also, in the past I have been able to fish a nut plate into the cavity using a piece of string. Once you get it back into the right spot you can put one bolt in to hold it while you install the hinge. Hope that makes sense. I don't know if there is a way to get a nut plate up to the upper hinge though.
Old December 10th, 2014, 02:05 PM
You could weld a nut plate to a stiff wire and try to fish that up thru the upper wing bolt square hole where the spire nut goes. Then just bend the wire such that you can hold onto it next time you undo the bolts.
Again, if it's all that bad you really aught to do it the right way. It doesn't mean a total disassembly of the whole bulkhead, but you'll prolly want to take the windscreen off.
Old December 10th, 2014, 07:51 PM
asetliff's Avatar
asetliff
Adam Setliff
Thanks guys for all your input.
This truck was recently painted but prior to my ownership, and I know they were in there but have no idea of the extent of it. I know it's a slippery slope with bulkheads and don't want to bite off more than I can chew. I wish I would have just left that bolt alone....
I'll get pictures when I get back home. I'm on the road for work until Friday.
Old December 13th, 2014, 02:22 PM
asetliff's Avatar
asetliff
Adam Setliff
Hinge in question.
Old December 13th, 2014, 02:54 PM
That is a bondo-filled mess, and not stock.
-Jeff
If you had that blasted you'd actually discover you have very little metal. That wasn't a previous repair, someone covered up the rust with bondo then painted it.
Old December 13th, 2014, 10:28 PM
asetliff's Avatar
asetliff
Adam Setliff
I cut the hole based on the size of the captive nut and tightened it up.
ac, door, series
Bumper captive nut tricks chris snell Defender Technical Discussions 7 October 5th, 2014 11:46 AM
Riveted captive Nut for seat frame bjf Wanted 7 July 10th, 2012 06:59 PM
ALQ710020 Bumper Captive Nut Block jefhuf Wanted 4 October 23rd, 2011 11:03 AM
ST b-pillar diagonal support captive nut plates dave_lucas Wanted 12 September 9th, 2011 02:57 PM
captive nut for wing intake cover Overlander Defender Technical Discussions 3 July 20th, 2008 11:51 PM
