Drum brake pad cracks? - Defender Source
Old July 7th, 2012, 02:18 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
Is this brake pad supposed to be or is this normal /ok?
Cheers
Chad
Old July 7th, 2012, 04:17 PM
No...definitely no ok. I *think* that's caused by too much pressure of the brake shoe against the drum. How old are the brake shoes?
Old July 7th, 2012, 05:33 PM
triple9music
Chad Davis
1984 Defender 90
Their brand new. Couple months but shady mechanic.
Old July 7th, 2012, 06:15 PM
What brand are they? Could be a manufacture defect too...may be worth contacting the company directly.
Rears on early D's were drums too (unless the rear axle has been replaced/updated, which is a common change).
Old July 7th, 2012, 06:52 PM
triple9music
Chad Davis
1984 Defender 90
It's a series 2a. 66 or 68 not 100% sure. Those are proline from rovers north. The truck is owned by one of the members of our club and they didn't look to be right to me. He was having to pump the brakes a lot and had intense vibrations at about 40 mph. After we took the pressure off the drums/pads, no vibrations and the brakes aren't stiff but are working better. Needing to bleed them I think. Before we worked on them the wheels were super stiff when on the lift. Now they move easily.
Old July 7th, 2012, 07:22 PM
Hmmm....so if they were mal-adjusted with too much pressure on them initially (ie tough to spin the wheels), that would build up some decent heat - which would crack the pads. I think we have the culprit.
Old July 7th, 2012, 07:28 PM
triple9music
Chad Davis
1984 Defender 90
god I love this forum
Old July 7th, 2012, 10:29 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Looks like a 4cyl 109 front.
Heat will do it.
Linings (pads are on disc brakes) will also crack from loose rivets. But these look to be bonded linings.Other things that will cause it is mismatch between the linings and drum (different arc radius). You can get this when a drum is turned and the linings aren't sanded down to match. Or it could be a mfg defect.
Are you sure they are new? The metal part of the leading shoe looks to be pretty rusty for being new. Looks like a lot of rust on the lining also.
In any case, when replacing them, the new shoes need to be centered as part of the installation/adjustment process.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 7th, 2012, 11:23 PM
chasrover's Avatar
chasrover
I'm a friend of chads working on this project today. The shoes are new no rust just the lighting I think. I think heat is the culprit as well. I think you are on to something with the radius not matching they looked closer to the edge near the middle than at the ends. We adjusted the snail cam all the way out and they still rubbed. I have seen other posts on the springs causing trouble. Does anyone have a picture of the proper spring set up for the front brakes on a 109. I think we had it right but it would be nice to see a pic.
ac, brake, rack
Transfer case leak - through trans brake drum nathanwind Defender Technical Discussions 29 July 17th, 2012 05:07 PM
Turning the Brake Drum? ]-[ @ n $ Defender Technical Discussions 6 February 28th, 2012 09:26 AM
Blew u-joint in rear, help on 4 bolts removal on brake drum UpnOver Defender Technical Discussions 3 February 2nd, 2012 07:53 PM
FS Salisbury Drum Brake Parts Stmpede For Sale - Parts 3 December 18th, 2008 08:02 PM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
