Designa coil 109 chassis - info? - Defender Source
Old April 8th, 2016, 11:43 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Gents,
I have seen a few buildups on here using Designa coil chassis for Series vehicles. I am looking for information as to how the crossmember that supports the rear A-frame is designed on the 109 chassis. It looks like it sits within the frame instead of on top of it, due to the difference in the shape of the Series chassis, but I have not seen any good photos of how it is actually built. Does it use the bolt-on brackets that are on RRC and Defender 110 chassis? Is it the same piece that is used on other chassis, or a custom piece?
Iím thinking of hanging coiler brackets on a HD 109 chassis I have and trying to figure out how to do it cleanly.
JL
Old April 8th, 2016, 11:46 AM
It is exactly the same as a 110. A frame arms are connected to the bolt-on brackets.
Old April 8th, 2016, 11:51 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Excellent. Thanks Bill.
Only good pic I found is this one from bossman429's thread. It looks like the exact same crossmember as is used on a 110 chassis, but mounted flush with the frame top rail:
Name:	109 designa.jpg
JL
Old April 8th, 2016, 12:12 PM
More Designa chassis porn here:
http://www.defendersource.com/forum/...tml#post349581
Old April 8th, 2016, 01:28 PM
oilburner's Avatar
oilburner
JL
large pile of parts
That's the stuff! I went over that whole thread but I must have skipped ahead to the assembly pics. Those shots are perfect.
I think the profile of the frame is a little different from a real SIII chassis though, seems like the bottom of the rail steps up a bit sooner at the rear and at a lesser angle. regardless, it shouldn't really matter anyways.
Edit: The front of the frame looks nearly identical. It's at the rear that it looks a little off. Then again, without the spring mounts, it's hard to compare.
JL
109, coil
Coil Immobilizer - Genuine Land Rover Part AMR4897 - COIL ENGINE IMMOBILIZER Ben01 For Sale - Parts 1 January 17th, 2016 05:40 PM
Designa chassis bossman429 Misc. Chit-Chat 13 January 13th, 2016 08:04 PM
Steering stabilizer for 109 designa chassis and RRC axles WildBoar Series Technical Discussions 17 May 19th, 2014 01:25 PM
109" Designa Coil Chassis and running gear dieselrover For Sale - Parts 4 November 6th, 2008 07:22 PM
Wanted- Defender or coil spring 110/109 for Series 109 conversion Rovermn Wanted 1 August 4th, 2008 06:04 AM
