Delco alternator w/ Lucas ignition switch and ammeter schematic - Defender Source
Old June 24th, 2016, 12:03 AM
Michel's Avatar
Michel
Michel Bertrand
1991 110SW 200tdi, 1963 109 2 door
Hello to all of you,
I am trying to rewire my ignition/alternator circuit for my SIIA. I have the GM alternator, a Lucas ignition switch from a 71, and the ammeter.... Does anyone have the homemade wiring diagram around that could be scanned? I can't figure what goes to where... Thanks,
Michel
Old June 26th, 2016, 06:55 AM
KB1IAW
Paul Dunn
1971 Series IIA 88
From TeriAnn's site:
The Delco 10-SI and 12-SI Alternators
Old June 28th, 2016, 07:36 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
In addition to the picture above, you might need a different ammeter. If the alternator can supply more current than the ammeter can take, it will blow. When it does you will not be charging anymore (and you might have a fire).
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Old June 28th, 2016, 07:50 PM
only if you are drawing that much. Which will very rarely happen on that vehicle.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 28th, 2016, 08:22 PM
That's silly. Of course it won't blow. It'll peg high but that's all. If you mean the alternator will blow that's wrong too. You can certainly use the 2A ammeter. I do and with a 65amp alt it has not pegged ever.
Old June 30th, 2016, 10:15 PM
Michel's Avatar
Michel
Michel Bertrand
ThanksPaul for the drawing to TerriAnn's diagram. I still am trying to figure out the relationship between the ignition switch, the Ford Solenoid and the GM alternator. I know, my 109 looks like it could belong to the adopted son of John Snow and Ramsay Bolton... If anyone is willing to play connecting the dots to help me out, here's a drawing of my various components I am trying to connect together. I wrote a letter next to each post/connector.
Michel
Old July 1st, 2016, 05:18 PM
KB1IAW
Paul Dunn
1971 Series IIA 88
This is how my late IIA ignition switch is wired:
If you look closely at the back of your ignition switch you'll see that the terminals are labeled 1 through 4. Position #1, the double terminal at the top in this photo is 12v in. #2, as you turn the key clockwise, is ignition on, +12v to your coil. #3, the single terminal at the bottom is the momentary switched position, +12v to your starter solenoid. Position #4, the double terminal, turning the key counterclockwise from the off position, is the auxiliary power position.
Name:	Ign Switch.jpg
Old July 2nd, 2016, 11:52 AM
Michel's Avatar
Michel
Michel Bertrand
Thanks Paul for the Lucas switch guidance. I have connected the wires trying to figure ir out from TerriAnn's drawing, Paul's cues and some handmade eiring diagrams from 1992 when I first did this on my 109...
I have managed to get the charging light to come on when turning the key to the ON position, get the engine to start and the alternator to charge as I can see the ammeter needle moving, but I can't get the engine to stop by turning the ignition off... I can kill the engine by removing a wire from the #1 terminal on the Lucas switch.... Not too convenient. I must have wired something wrong, but I have no clue. I have attached a diagram of the actual setup. Does anyone have any idea? It probably is something obvious...
Michel
Old July 2nd, 2016, 03:21 PM
Michel's Avatar
Michel
Michel Bertrand
Fixed! I had two wired inverted (coil to switch position #1 and alt wire going to switch position 2). Duh.
Old July 2nd, 2016, 04:17 PM
KB1IAW
Paul Dunn
1971 Series IIA 88
Great news, Michel!
alternator, switch
WTB: Ammeter illumination bracket ROBINSON110 Wanted 5 February 22nd, 2016 10:31 AM
New genuine Lucas Distributor - Lucas 35D8 pabrit For Sale - Parts 0 June 1st, 2012 04:13 PM
schematic for electronics in a '94? ollieskins Defender Technical Discussions 0 December 8th, 2008 05:47 PM
Delco Alt. Conversion Info Stmpede Defender Technical Discussions 7 November 6th, 2007 10:59 PM
picture/schematic HillWilly Misc. Chit-Chat 1 September 18th, 2007 03:16 PM
