Defender Fender Flares on a Series? - Defender Source
Old April 12th, 2011, 01:33 PM
paydan
Norberto
1979 RHD Series III
Can anyone tell me if a set of Defender fender flares will fit on a Series III? I have asked several people and got two different answers. Yes and no I am mostly looking for a direct fit if possible. I figured that I would ask you guys in here before I bought something that I couldn't use.
Old April 12th, 2011, 02:21 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
The arch is different at least on the front of the defender. I'm sure they could be made to fit, but not direct fit.
Daniel
Old April 12th, 2011, 04:45 PM
paydan
Norberto
1979 RHD Series III
Awesome! Thanks for the information. That is exactly what I wanted to know. I just purchased two new front skins from Safari but they are for the series. Since they are the plastic ones I don't want to cut into them. That is what I was afraid I was going to have to do. I know that they make some for the series somewhere so I will just keep looking for some of those. Thanks again you guys.
Old April 12th, 2011, 04:48 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Defender outer front wing panels will bolt straight on but the axle is positioned 2" further back on a defender so the hole isn't in quite the right place, it will go on but doesn't look quite right.
Unless you are fitting very wide wheels or RRC/ Defender axles. wheel arches look rather strange on a Series,
the wheels come nowhere near filling the arches.
Mike Hammond
Old April 12th, 2011, 09:22 PM
paydan
Norberto
1979 RHD Series III
I actually have RRC axles on my series so my wheels stick out beyond the fenders.
Old April 13th, 2011, 04:21 AM
mikeslandrover
Mike Hammond
Early series II Long Wheel Base rims have the extra width inset and look like SWB rims, they'll put the wheels inside the bodywork, just, with 7.50 16's. Trouble is they're rarer than hens teeth.
Mike Hammond
Old April 13th, 2011, 12:07 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I put early 2a 16" wheels from an 88" rig on my 109/110. I'm running 235/85/16 mud terrains and they just barely stick out past the body and I think look just right. Good luck.
Daniel
Old April 16th, 2011, 10:08 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
I have early pre-Defender outer wing panels bolted to my Series truck. The Defender cut outs are both higher and longer. The extra length is mostly at the rear which makes the front wheel look off centre.
I have attached 2 pictures. One show a Defender outer wing panel sitting on a Series outer wing panel showing the differences in the wheel arch. The second one has the front of my truck with Defender outer wing panels and 33 inch dia tyres next to a truck with stock Series outer wing panel and 32 inch dia tyres. I added the Defender panels to gain additional clearance for 35 inch tyres.
As far as wheel arches are concerned, they bolt to the wheel arch flange. So you can not just cut out a Series outer wing panel and fit Defender arches unless you bend in new flanges.
However arches for Series trucks are available in the UK. Check the big LR parts houses and you can get some that fit a Series wheel arch.
ID:	37902   Click image for larger version
TeriAnn
Old April 16th, 2011, 12:12 PM
paydan
Norberto
1979 RHD Series III
Wow! Thanks for the pictures and the description TeriAnn. I don't think that it can get any better than that. Since I just bought new wing panels, I am looking for some series arches in the UK as we speak. Thanks again. Awesome post.
Old June 15th, 2011, 03:53 PM
Wander's Avatar
Wander
Matt
97 DI SD 5 speed
Here's a picture of my buddies SIII 109 with Disco axle's and Defender wheels. He doesn't have the Defender wings but he does have flares. I'm not sure how what he used or how he did it (I'll ask) but it came out clean and covers that extra bit of tire.
Name:	Old Rovers in Greenville.jpg
~Matt
__________________________________________________ ___________
It's the journey that matters
Old June 15th, 2011, 06:06 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
A few years ago I put a set of "Defender-ish" arches on my weird hybrid project (first D/D-lite), and as I recall I got them from Al at DAP. (Bearmach made, maybe?)
They mounted differently than Defender ones, but were made for the Series arches. Required no cutting, and the arches were screwed/bolted into the rolled/folded edge facing the tire. Then, the top, body-contacting edge had pieces of weatherstrip for a cleaner look. I have no idea if they're still available, but I'm 99% sure I bought them from DAP after seeing them on their site.
The truck had Series III front panels and rear panels from a Series III 110 Regular cut down to fit the 100" RR wheelbase, but had unaltered Series arches front and rear.
Photos attached of the truck without it's top a few months before I sold it in '06.
Note oil spotting on otherwise new driveway. It's a Rover V8.
Murph
ID:	39698   Click image for larger version
ID:	39700   Click image for larger version
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old June 19th, 2011, 09:35 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I purchased those wheel arches for a series IIa from M & M 4x4 in England. Ask for Becci.
Old June 19th, 2011, 10:42 PM
It is very easy to change the opening to fit the flares in the correct location. Cut two pieces of plywood the correct shape. Clamp to the skins. Cut 1/2" away and then hammer in to create the lip.
Old June 21st, 2011, 09:44 PM
paydan
Norberto
1979 RHD Series III
Chris,
Your rover is friggin awsome. I am looking to about the same thing with mine. Do you by chance havve any other pictures or a build thread? Great work man!
Norberto
Old June 6th, 2012, 08:28 PM
Bricktop's Avatar
Bricktop
Jon Paulikonis
1998 Discovery
Helobubba - that is one of the best looking hybrids I've ever seen!
Old June 7th, 2012, 12:15 PM
ukoffroad's Avatar
ukoffroad
Chuck Yarbrough
67 IIA
X2. That hybrid looks awesome.
Chuck
67 Series IIA
The parts falling off this vehicle are of the finest British craftsmanship.
Old June 7th, 2012, 12:48 PM
Gold Bug's Avatar
Gold Bug
Trace
2003 Discovery SE7 *SOLD*
+1
Awesome
series
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
Defender or Series Fold Down Side Steps boshea For Sale - Parts 1 June 17th, 2005 03:57 PM
defender fender flares WhiteD90 Wanted 2 June 9th, 2004 08:19 AM
D90 fender flares for sale Chris Cox For Sale - Parts 10 April 23rd, 2004 02:42 AM
