defender/110 vs series truck cab - Defender Source
Old August 27th, 2011, 04:21 PM
Dr Benway
Haydn
none
I believe the roof panels are different, due to the different height windscreens
but; is the rear [vertical] back section of a series 2/3 truck cab the same as a later-- 90/110/defender?
In other words will a series 2/3 truck cab roof panel, fit on a later truck cab back/body-- and will that bolt on to a series 2/3 truck?
any help/advice much appreciated
thanks!
Old September 2nd, 2011, 02:54 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The 90/110 rear truck cab body will bolt onto a series tub & roof.
Mike Hammond
Old September 2nd, 2011, 06:05 PM
Dr Benway
Haydn
none
thanks!
Old September 4th, 2011, 03:18 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
The only difference is the leading edge that mates to the windscreen to the bulkhead. Otherwise they are the same. I have done this swap and it is not a big deal. All you need to do is fit a later defender windscreen to a series bulkhead or fit a series windscreen to a defender bulkhead. You will need to use the defender windscreen mounts to attach the frame to either bulkhead. You will want to cut off the series windscreen mounts as they get in the way but otherwise it can be done.
Best of luck
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old September 6th, 2011, 12:03 PM
Yes, early 90/110 is the same as series. Later defender have the rounded windows. Not sure when they changed.
Old September 6th, 2011, 12:52 PM
mikeslandrover
Mike Hammond
I think Haydn just wants to swap the rear pannel
Mike Hammond
Old September 8th, 2011, 09:29 AM
Dr Benway
Haydn
none
thanks all, for the info/replies
I had found a brand new cab top/roof panel, and was looking for the rest. 90/110 are easier to find.
thanks
110, series
71 Series III Double Cab RHD 2.5 Petro Rugbier For Sale - Vehicles 3 July 20th, 2009 12:58 AM
For Sale: 1971 Land Rover Series III Truck Cab, $16k, Scottsdale, AZ azarmadillo For Sale - Vehicles 0 February 13th, 2009 10:18 AM
Pick Up Truck Cab $700 evilfij For Sale - Parts 17 February 11th, 2009 09:39 PM
