D90 frame stretched to fit a Series 109..Pros/Cons - Defender Source
Old January 24th, 2014, 01:55 PM
BigWalker's Avatar
BigWalker
Pete Ricci
1965 Series 109 V8 Automatic
Has anybody stretched a D90 chassis to fit a series 109 or 110?
I was thinking this would be a lot easier then using either a Disco or RRC chassis
I know there are some folks stretching these for 130 builds.
Pete
Old January 24th, 2014, 02:10 PM
Not very cost effective I'd think. There are a ton of RRCs and Discos around in junkyards, and probably only a handful of D90s in junkyards. I've seen quite a few using RRC and/or Disco frames used for Series hybrid projects.
Old January 24th, 2014, 02:16 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
It can be done... But you might just consider using a 110 frame instead. In addition to the front tub mounts being different, the rear overhang behind the axle is shorter on a 90 than a 110 as well, so it would have to be stretched there too.
They are not compatible, it would involve a TON of work to make it all go together. The curves in the frame are way different.
I have seen it done, mainly by welding a crap load of angle stock all over the place.
Old January 24th, 2014, 02:17 PM
BigWalker's Avatar
BigWalker
Pete Ricci
So as I understand it with a D1 / RRC frame I have to totally replace the body mounting and stretch & add a cross member= time and monies
With a D90 frame don't I just need to stretch & add a cross member?
------ Follow up post added January 24th, 2014 02:21 PM ------
Bill I assume you are referring to the 90 frame?
Old January 24th, 2014, 02:21 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
See Bill's post above... It's not just as simple as stretching. Adapting a d90 frame to a 109/110 would be no easier than using a disco frame, stretching it, then cutting off the frame beind the rear spring buckets, then making a new frame up to the rear crossmember. If fabrication is your thing, go for it. If not, save yourself a lot of time and just buy a 110 frame
Old January 24th, 2014, 02:25 PM
Not really. A D90 frame has completely different bulkhead and body mounts than a Series. You'd be cutting off the bulkhead outriggers, the tub mounts, the entire rear chassis, and probably some other stuff I can't think of. Then you have to buy those bits new and reweld them in place, being sure that they all line up properly.
Old January 24th, 2014, 02:34 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Bill he could actually leave the bulkhead outriggers as is. Yes the defender outrigger is different than the series but that is mostly because the frames are different. The mounting and location are the same. However there is plenty of other work to be done.
Old January 24th, 2014, 02:42 PM
I thought the defender bulkhead mounted behind the outriggers and the Series in front. Maybe I am confused due to my limited Defender knowledge. As you say that's the least of it...
Old January 24th, 2014, 03:03 PM
pm sent
------ Follow up post added January 24th, 2014 03:12 PM ------
if you use a RRC lwb chassis there is no lengthening just rear cross member and outrigger changes.
I have a 110 and lwb chassis sitting side by side for comparison if you'd like to come to the shop- about 2 hrs East of you.
Old January 24th, 2014, 08:06 PM
BigWalker's Avatar
BigWalker
Pete Ricci
Originally Posted by The bigger issue is both 109 and 110 frames have a deeper crosssection to deal with the extra weight/leverage.
-Jeff[/QUOTE
Now that' raises a whole different concern! I will need to look into this because should I want to outfit for extended travel I can't risk using a light weight frame
------ Follow up post added January 24th, 2014 08:12 PM ------
PM sent
Thanks for the offer I will get with you to come and take a look
Old January 25th, 2014, 11:23 AM
Pete
From what I've seen, the factory welds in an extension in the middle of the frame to lengthen a 110 frame to 130. This may only be on older trucks, I don't think I've seen any newer 130's.
Old January 25th, 2014, 11:27 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Somewhat related, is it of any value to hang on to a RR LWB frame(108")?
A friend is sending one to the scrapper soon.
I don't follow Series builds much any more so I dont really know.
Rent my
Old February 10th, 2014, 10:47 PM
BigWalker's Avatar
BigWalker
Pete Ricci
Final note. I am moving forward with a D1 stretch. The D90 rolling chassis had other issues anyway
109, 90, d90, series, series 109
Frame up restoration - '61 Series II 61rover Truck Build-up's & Restores 37 November 11th, 2013 05:23 PM
Series III 109 SW conversion to a ST gas-man Series Technical Discussions 2 June 26th, 2010 12:44 AM
1967 Nada 109, on 110 frame btate For Sale - Vehicles 9 November 23rd, 2009 09:26 AM
D90 and Series Parts for sale rrubino2 For Sale - Parts 20 January 26th, 2005 05:31 PM
