Coolant Leak Discovery Series II - Defender Source
Old January 20th, 2010, 08:22 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I have a 2003 Disco II with 60k miles on it. It's due for the 60k service and an oil change.
When I was getting fuel yesterday I checked the oil and noticed an orange gel over my head cover on the left side under the TBI. Checked the coolant and it was at about half. I noticed a funky smell about a week ago but it hasn't been consistent. No new stains on the driveway, no change in performance or increase in temp.
Coolant has covered the top of the head and appears to be coming out of the TBI. Where should I start to address this problem? Is this a sign of a much larger issue?
Alex
ID:	24587   Click image for larger version
Old January 20th, 2010, 08:37 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
You're lucky...very common coolant leak on a D2.. the throttle body pre-heater plate gasket goes out... fast easy fix... buy a new kit;
http://www.roverparts.com/Parts/MGM000010KG.cfm
switch out the gasket and the plate and you should be fine.
------ Follow up post added January 20th, 2010 08:38 PM ------
Here's the TSB too;
SERVICE ACTION
Throttle Body Heater Gasket Replacement
AFFECTED VEHICLE RANGE:
DISCOVERY SERIES II (LT) XA200412 to XA208015
XA900000 to XA904569
SITUATION:
DURABILITY IMPROVEMENTS TO THROTTLE BODY HEATER GASKET
A change in material used for the throttle body heater gasket improves the service life of the component.
RESOLUTION:
REPLACE GASKET WITH NEW SPECIFICATION GASKET
Under this Service Action the new-specification throttle body heater gasket will be installed to improve the reliability of the vehicles within the specified VIN range.
PARTS INFORMATION:
NOTE: Early specification spare parts held in retailer inventory may be returned using the PAF claim process. Use reason code OH and reference this TIB on the claim.
MGM000010K Throttle body plate kit Qty 1
ERR6623 Throttle body gasketQty 1
ITEMS INCLUDED IN THE MATERIAL ALLOWANCE:
^ (Locally Sourced)Liquid gasket remover As Required
^ LRN0002LABEL Campaign label Qty 1 (Order quantity 1 = 100)
WARRANTY CLAIMS:
H230 (Option 1) Time 1.00 hrs.
Perform gasket replacement
Material Allowance: $2.00
H230 (Option 2) Time 0.20 hrs
Inspect throttle body and determine that Service Action is not required
NOTE: In order to determine if a specific vehicle is affected by this Service Action, it will be necessary to utilize the Vehicle Warranty/Recall Search function of the DCS - Land Rover Link On-line. Based on the response of the system, either proceed with the corrective action or take no further action.
Normal warranty policy and procedures apply
REPLACEMENT OF THROTTLE BODY HEATER GASKET
INSPECT TO DETERMINE THROTTLE BODY PART NUMBER
1. Locate the part number tag on the throttle body.
2. If the part number on the label is not "MHB101890", go to "Campaign Label Installation" and perform label installation to identify that the vehicle has been inspected. Claim Option 2.
3. If the part number on the label is "MHB101890," complete the repair.
SERVICE ACTION REPAIR
1. If the part number tag reads "MHB101890," remove the throttle body following Workshop Manual procedure in Section 19.22.45.
2. Disassemble throttle body as follows:
^ Remove the three water jacket screws.
^ Remove the water jacket cover.
^ Discard the cover, screws, washers and gasket.
CAUTION: Metallic tools or abrasive material can cause damage to the gasket surfaces. Only liquid gasket remover should be used.
3. Remove the remains of the old gasket from the throttle body using care not to damage the housing.
4. Ensure the throttle body water jacket cover mating face is thoroughly clean.
5. Install the gasket, cover and screws supplied in kit MGM000010K. (Figure 1)
6. Tighten the screws to 4.0 - 4.5 Nm (35.4 - 39.8 lbf.in.).
7. Apply the new identification label to the throttle body.
8. Verify that the mating faces of the throttle body and inlet manifold are clean and all gasket material is removed.
9. Refer to Workshop Manual Section 19.22.45 and install the throttle body using a new gasket (ERR6623).
10. Install coolant hoses using clamps previously removed.
WARNING: Spilled fluids can be a hazard. Ensure that any fluids spilled during repairs in the under-hood area are cleaned up.
11. Top up the coolant system.
12. Road test the vehicle and verify no leaks are present.
CAMPAIGN LABEL INSTALLATION
NOTE: Campaign labels may have multiple campaign numbers written on them if multiple campaigns are performed at the same time.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old January 20th, 2010, 09:27 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Thank you! Seems simple enough. BTW how do I clean the orange goo from the head cover?
Old January 25th, 2010, 12:04 PM
rmuller
Ryan
I just usually wipe it off... use some brake cleaner or gunk or something.
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
coolant, cover, disco, discovery, series
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
1999 Discovery Series II for sale mgrgpg For Sale - Vehicles 1 May 21st, 2004 08:17 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
