? Converting a series from right hand to left drive - Defender Source
Old November 19th, 2011, 10:01 AM
JBinAlabama
john
Series 2A ..more parts on the way
Hey guys,
I have my series totally disassembled now and it's left handed.
I have seen a lot of right hand drives for sale........is it hard to convert one?
It looks like most have all the bulkhead holes in place for either.
So is the biggest problem the steering block on the chassis?
Old November 19th, 2011, 10:33 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
It's fairly easy to switch... the steering box being the hardest part. This is assuming you have the stock 2.25 engine in it.
As far as I know, all Series trucks have holes on both sides.
Old November 19th, 2011, 11:25 AM
JBinAlabama
john
Thanks Doc,
I'm out of town (FSU football game tonight) and my chassis is still at the galvanizer so I can't see right now and am curious. The is a RHD truck for sale today I'm interested in
Old November 19th, 2011, 12:00 PM
navydevildoc
Neill Thornton
Well, if you already have the steering box out you have done the hard part. Usually it's a swear word inducing event.
Old November 19th, 2011, 02:25 PM
JBinAlabama
john
Yep, and a damn big hammer
Old November 20th, 2011, 08:28 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I'm not sure about moving the battery, I've got a LHD and RHD with the battery in the same place on both. You will have to find the arms right steering arms. You might get away with just finding the left side and leaving the right side as is. It would just have an extra hole in it.
Ser IIa and earlier are going to be much easier than a Ser III.
Old November 20th, 2011, 09:59 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Your title says Right to Left, but your message says it's LHD. Which is it?
Or are you actually looking to buy a RHD also?
I can't think of any reason to convert a LHD to RHD in the US.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 20th, 2011, 12:23 PM
Install a P38 PS box and forget about the steering relay. You can use a defender steering column. Make a huge improvement.
Old November 20th, 2011, 05:11 PM
JBinAlabama
john
Oops. I currently have a left hand drive.
But I'm looking at a right hand drive and would like to convert it to left hand.
Do you have a link to the p38 conversion?
Old November 21st, 2011, 08:06 AM
Antichrist's Avatar
Antichrist
Tom Rowe
There's video on youtube of the scout PS conversion.
As long as you have the huge Series steering wheel I've rarely really wished for power steering in a Series. Not often enough to really even contemplate converting it.
As for the conversion, as others have said it's not a huge deal.
Some chassis have a hole for both RHD and LHD relays so that would make it even easier.
Don't forget the parking brake parts if you don't want to have to reach across the tunnel.
Here's the IIa parts book. You can see what parts are different and which are the same.
http://www.scribd.com/doc/34174887/L...2-2A-Parts-Cat
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 21st, 2011, 08:14 AM
Bill, have you seen a write up or know anyone who has converted a 2.25 to power steering? Ive been thinking on converting my dads S3, but am wondering how much power is robbed, how nice of a conversion it is. FWIW Id be using a Scout2 box.
-Jeff
TeriAnn has a pretty good guide on her pages. However, those all have some honking big plate welded to the frame. I think that's overkill. A backing plate on the opposite side of the frame where the bolts go thru has proven to be plenty of reinforcement. You need to rework the Scout pitman arm, as it is too long and needs a Rover taper in the end for the TRE.
Hanging the PSP on the engine is all on you cuz I already had the mounts on the V8. I think it has been covered in the TAW web pages noted above. I have a Jag version of the Lucas dynamo which has a PSP on the end of it. An oddball thing but an elegant solution to the power steering that nobody has ever documented. It's yours for shipping if I can find it.
When I do the power steering on the 109 project it will be a RRC box connected to the 20 Tdi PSP via braided Aeroquip or Russell hose and fittings.
Old November 21st, 2011, 09:51 AM
slorocco
Dan Prasada-Rao
Isnt the battery support on a RHD a bit different (but same location) to clear the intermediate linkage rod? It has been a while since Ive seen one, but I thought it was different. I could be mistaken, just going on memory.
-Jeff
Hmmm, that could be the case, I'll have to take a closer look now that you mention it.
Old November 21st, 2011, 10:25 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I recently did the p38 power steering conversion on my series truck. I'm not done with the rest of my project so I haven't had a chance to use it, but I did weld on 1/2" plate to the side of my frame and some gussets at the top where the box and plate for the upper mounting holes sits above the frame. The scout box may be different than the p38, but the p38 mounting holes are far enough apart top to bottom that bolting thru the chassis isn't an option. There are pics buried somewhere in my build thread.
Hey Jeff I believe Tony on the mendo list has the p38 conversion on his 88" with a stock motor. Medhi has it on his series 1 with the 6cyl. rover engine and it doesn't seem to lack any power. He used a zf pump from a disco.
Here are some pics to show why you need the plate with the p38 box.
Daniel
ID:	43895   Click image for larger version
ht, series
71 series 2a incredible. better than stock stanman For Sale - Vehicles 9 October 4th, 2007 11:05 AM
Drive line problems HELP D90user Defender Technical Discussions 4 February 17th, 2005 10:19 PM
Drive Line Vibration reggie Defender Technical Discussions 4 May 13th, 2004 12:27 AM
Need Left Wing outer shell vnrover Wanted 8 April 8th, 2004 12:56 PM
