Converting a 2003 Discovery to a 300tdi - Defender Source
Old August 4th, 2014, 07:09 PM
fletch
Chris Fletcher
2003 Land Rover Discovery
I'm considering converting my 2003 Land Rover Discovery to a 300tdi engine. Is there a good place to purchase the engine and transmission? Has anyone had any experience with Land Rover imports (Duncan Goodchild)?
Old August 4th, 2014, 07:17 PM
Just realize that there is a lot involved with a D2 in changing the engine and making the rest of the car still work. Using the correct (TD5) engine from a donor Disco with all the correct other parts may be easier.
I've not dealt with Duncan, but a search on this site is probably a good place to start.
Old August 4th, 2014, 07:28 PM
It can be done, but I highly doubt most people would be able to do it and still have everything work correctly. As John said, a TD5 swap would be a better choice, but still a huge task to install. A TD5 feels way more powerful than a 300 tdi in my opinion. Make sure you do all of your research before you start ordering parts.
Old August 4th, 2014, 07:44 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
plus even with a Td5 the disco is a slug, way too small engine for that truck
- Charles Eames
Old August 5th, 2014, 11:25 AM
Maybe stock, but they can be safely tuned up to be faster than the stock V8s.
Old August 5th, 2014, 11:27 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
X2 with ecu upgrades readily available. The power band is an old argument. I still like the diesels across the board
Old August 5th, 2014, 11:41 AM
Not to mention OBDII emissions testing and the state-to-state issues that would arise when it comes time for you to sell. how will it be titled (diesel, gas?), etc.. Check out Roving Beetle's thread on his diesel in a D2 swap.
http://www.defendersource.com/forum/...ad.php?t=19050
Old August 5th, 2014, 11:56 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
A quick search will answer you questions about the seller…
Do you have emissions in Chicago? If so, this will not pass as in theory you can't put in a engine older than the vehicle and is not OBD2 compliant . Anything can be done, but do a more research on the topic and feasibility of that engine, and along those lines, the amount of work needed to fit any diesel into that truck...
2003, 300tdi, cover, disco, discovery, tdi
Converting Discovery / Range Rovers to 200tdi or 300tdi diesel - pictures here ZombieMotors Truck Build-up's & Restores 0 March 17th, 2013 01:00 PM
Converting to 300tdi - question re: R380 fitting jaherring Defender Technical Discussions 14 June 6th, 2010 12:33 PM
For Sale 2003 Discovery SE asking 16k or obo januconn92 For Sale - Vehicles 2 October 15th, 2007 10:09 PM
For Sale: 2003 Discovery S bernardmann For Sale - Vehicles 2 July 16th, 2006 04:39 PM
Original 2003 Trek Competion Discovery TD5 Auto, LHD. Trek Jon For Sale - Vehicles 11 August 30th, 2005 06:35 PM
