Cold Galvanizing Compound - Defender Source
Old July 19th, 2013, 06:29 PM
The Dro
Dro
1988 Ninety
Some areas of the body capping have lost the zinc coating.
Has anyone tried these compounds?
http://www.grainger.com/Grainger/RUS...Compound-3BU16
Old July 19th, 2013, 06:33 PM
I have used it to touch up galvanized boat trailers. They sell it in spray cans- CRC makes a better version.
Old July 19th, 2013, 06:39 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
X2 on the CRC. You can also squirt a little satin finish clear over it too.
Old July 19th, 2013, 08:23 PM
The Dro
Dro
1988 Ninety
Sorry for the million questions...
Do I need to remove the capping from the truck?
Or taping the aluminum with the blue tape will suffice?
Old July 20th, 2013, 06:46 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Cold galvanizing compounds look somewhat like hot dip. They don't protect anywhere near as well has hot dip. IMO their only use, pretty much, is to mimic the hot dip color. Despite claims to the contrary my experience is that they provide very little more protection than good paint.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 20th, 2013, 09:14 AM
The Dro
Dro
1988 Ninety
I'm debating doing it.
What concerns me is the quality and look.
Price-wise hot dip is $1/lbs and cold is ~$190/Gal.
The body capping are less than 50 lbs.
Old July 20th, 2013, 11:12 AM
if you are concerned about rust then take it apart. If this is just about restoring the appearance then use a $10 can of spray ZINC IT. Its 92% zinc so
the closest thing you can get to the finish with out the hastle.
http://www.crcindustries.com/faxdocs/tchdta/130.pdf
Old July 20th, 2013, 09:44 PM
The Dro
Dro
1988 Ninety
Thanks for the info.
galvanizing
Anyone tried Cold Galvanizing paint? SOUTHPAW26 Defender Technical Discussions 3 June 3rd, 2008 10:12 AM
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
a/c not cold jblieb Defender Technical Discussions 1 September 15th, 2005 10:34 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
galvanizing questions kit Defender Technical Discussions 4 October 21st, 2003 10:31 AM
